not sure how it would collapse the bottom hose with the metal spring thing in there that they put in there to make it not collapse. Either way, sounds like a cheap shot at fixing this. I'll give it a shot this weekend; I've put everything up now and it's time for bed (I work 3rd shift, school in the day).
Thanks for all of the help, and this thread will definately be revived win or loss.
EDIT:
Can someone elaborate on this a little more? I don't doubt this being true, but just kinda wanna understand how it happens. So...the cap has 16psi of pressure and 1hg of vac. So you're saying if the cap were bad, it would have too much vacuum and not enough pressure and that's what would collapse the hose? Can you explain why the fan would come on immediately after I turned the car off, but wasn't on right before when the car was way above operating temp (230ish).
EDIT:
Baskin said:I think may have I just figured it out, the valve in the cap is bi-directional. 17psi pressure, -1 psi vacuum, If the cap is bad, the coolant will contract and collapse the bottom hose when the fan comes on. Try switching the cap
