DCC users..I'm having problems...
  • Thread starter Thread starter TheUser
  • Start date Start date Oct 23, 2005
First Prev 2 of 2
T
TheUser
1,859
Springfield, MO
Oct 27, 2005
#21
  • Oct 27, 2005
  • #21
not sure how it would collapse the bottom hose with the metal spring thing in there that they put in there to make it not collapse. Either way, sounds like a cheap shot at fixing this. I'll give it a shot this weekend; I've put everything up now and it's time for bed (I work 3rd shift, school in the day).
Thanks for all of the help, and this thread will definately be revived win or loss.
EDIT:
Baskin said:
I think may have I just figured it out, the valve in the cap is bi-directional. 17psi pressure, -1 psi vacuum, If the cap is bad, the coolant will contract and collapse the bottom hose when the fan comes on. Try switching the cap
Can someone elaborate on this a little more? I don't doubt this being true, but just kinda wanna understand how it happens. So...the cap has 16psi of pressure and 1hg of vac. So you're saying if the cap were bad, it would have too much vacuum and not enough pressure and that's what would collapse the hose? Can you explain why the fan would come on immediately after I turned the car off, but wasn't on right before when the car was way above operating temp (230ish).
baskin
152
Oct 27, 2005
#22
  • Oct 27, 2005
  • #22
I'm saying that the pressure relief is 16psi, but coolant is non-compressible, so when it drops from 210 to 190, it contacts at a rate of about 1% over the 20 degrees. If the cap doesn't let coolant back in, the pressure will drop. The contraction over 20 degrees equates to about 12 cubic inches, so if your hoses were expanded less than 12 ci under the 16psi, you'll end up with one of two results, either the hose will collapse or you’ll end up with a drop in pressure to below atm, which will boil the coolant at a lower temperature. At about 8psi below atmosphere, for example, water boils at around 175
I can’t think of anything else that putting on the cap would effect. The change in pressure is the same on both sides of the thermostat and the sensor shouldn’t be effected at all.
T
TheUser
1,859
Springfield, MO
Oct 30, 2005
#23
  • Oct 30, 2005
  • #23
Although the LX ran fine w/ the radiator before, when it was in the GT, I had problems with it; took it to a radiator shop and he said the neck was warped - so buying a cap for it didn't seem to be a solution to me. I went ahead and purchased a $100 2-core stock replacement at the local O'Reilly's and everything seems to be good now
The car stays around where it did before - awesome! I only drove it around for a short time w/ minimal stop and go. I did stop to look at a truck for sale and the fan cycled a few times; I suppose that's what it's supposed to happen - the gauge didn't move much.
I also remembered to turn on the heater when burping it this time
Thanks for all of the help guys - especially Baskin
04sleeper
2,674
14
89
Dallas, TX
Oct 30, 2005
#24
  • Oct 30, 2005
  • #24
Glad to see you got it fixed.
HISSIN50
34
129
Oct 30, 2005
#25
  • Oct 30, 2005
  • #25
That was some real nice diagnostics with the cap/rad neck ideas from Brian.
Glad it is running good.
First Prev 2 of 2
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
