  • SVT Tech Forum
Dead 98 Cobra
  • Thread starter Thread starter jeremy canter
  • Start date Start date May 16, 2009
jeremy canter
402
Orange County , NY
May 16, 2009
  • May 16, 2009
Well I finally trade my convertible for what I want > but the down side is the guy who had it before me did something bad to the motor.> I got the car with a very bad tick in the top end / when I pulled the passanger sid evalve cover off > the no. 4 rear intake rocker was laying in the head.
So I'm pulling the head to see whats up in the motor . > Is there any thing I should look for while I'm in the mootr ? what up grade's should I do while I'm in the motor? I have found a set of 97 cobra heads cheap if I need a head > I do know I need a passanger side intake cam and the lobe that threw the rocker has a nasty scratch in it .
anyone with tips or hit's to more N/A power would be great!!
hotcobra03
poteet,tx
May 17, 2009
  • May 17, 2009
engine
looks like they never changed the oil.........
where are your fender covers?
too bad on the valve problem....get ready to spend some money
jeremy canter
402
Orange County , NY
May 17, 2009
  • May 17, 2009
day two and I didn't get much done >I'm ready to pull the timing chains and un hook the exhaust > time to see whats on the inside of this baby,
jeremy canter
402
Orange County , NY
May 18, 2009
  • May 18, 2009
YEA it open finally > after three days of working on it till I get Pi$$ed I finally got it open to day and man what a pITA> . my worst fear's have blown away as It was the past owners stupidity that did the motor .> the guy opened the motor to fix> something and he messed -up > his bad my good >
He proped a fuel line bolt that the wiring harness clips on too down the intakeand thats what got my valve >
IT DIDN'T EVEN HURT THE SEAT OF THE VALVE HAHAHA YES > so tomorrow I'll order a new valve and test the seat if it all looks good > is going back tegether this week
hotcobra03
poteet,tx
May 19, 2009
  • May 19, 2009
pics
how about the piston?
take the head to a shop and have them go over it
mine had a crack up the middle of the valves...
as to a cost,,,mine was close to 5hundred.....weld crack/resurface/3angle cut/1 valve/1 seat/pressure test..
i also pulled the other side...3hundred for that side'''
i also used oem headgaskets/bolts at a cost of 5hundred
frpp makes a headset for 100 bucks which i think you can use
jeremy canter
402
Orange County , NY
May 20, 2009
  • May 20, 2009
heads fine I already looked it over good and two cans of carb cleaner helped > I have already ordered the valve > as soon as it gets here > it's going back together > I'm not going to pull the other head > head gasket is $50 > I haven't priced head bolts > yet> I am going to replace the front main seal $30.00 > Intake gasket > $50 .00 ALL the valve seals and slap it back together $45.00 > I hope it go's together faster than it came apart > (3day) >
hotcobra03
poteet,tx
May 21, 2009
  • May 21, 2009
junk
i just did mine twice..1st time i pulled motor and assembled on stand....problem with cam bolts breaking(not torqued from machine shop)
2nd time pulled engine but assembled in the car....
fwiw...on the second time i pulled the oil pan just for looking and found oil pump screen clogged with silicone from front cover or something ford did do the head replacement when under warranty..and the oil cooler was full of junk...mine wasnt have as bad looking as your valve..my seat dropped about a quarter inch and the valve was still going up and down,,,,good luck with it anyway you go,,,just hate to here you have to do it twice for something that should have been done for basic change
jeremy canter
402
Orange County , NY
May 22, 2009
  • May 22, 2009
I ordered the Ford head bolts to day > I did take it to my buddys shop and he gave it a look said it looked good and the seat wasn't hurt > I'd be fine to just put a valve back in and go > so I had him order the valve from Ford yesterday . I'm going to use a Autozone head gasket> it's less than half the price of the ford one >> I do have a question > the cross-over tube that goes between the heads >
do I replace the rubber o-ring's on the bottom or what?
my motor is suppost to only have 60,000 miles on it would you replace the timing chain guides ?
hotcobra03
poteet,tx
May 22, 2009
  • May 22, 2009
parts
when i did mine i was broke...it only got what was needed...
my o-rings went back in pitted...no leaks
the timing chain guides if they are worn sure...
i highly suggest pulling oil pan...why...oil pressure...from what ive been reading ,,the mod engines are taller and its harder to get oil up into heads...thats why they use 20w oil...,,even if this isnt true...id still pull it
jeremy canter
402
Orange County , NY
May 22, 2009
#10
  • May 22, 2009
  • #10
I was thinking about than > I want to put a new pump in > BUT for $300.00 wow > it might be a week or two to swing that > sounds like my old baseball cards and comic book collections might join some of my Starwars stuff on CraigsList .com for sale > HAHAHAHAHAHAAHAH
jeremy canter
402
Orange County , NY
May 26, 2009
#11
  • May 26, 2009
  • #11
well I got the head / timing chains / timing cover / valve covers on today . hopefully tomorrow I can get the rest together and fire it up .
jeremy canter
402
Orange County , NY
May 28, 2009
#12
  • May 28, 2009
  • #12
well its alive took it up the road last night > going to put it on the road today !!!!!!!!!!!!!!!
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:03 AM
Mustang5L5
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
  • SVT Tech Forum
