deck surface cleaning
  • Thread starter Thread starter tbi92rs
  • Start date Start date Jul 4, 2006
T
tbi92rs
69
Louisville, KY
Jul 4, 2006
  • Jul 4, 2006
About to clean the deck surface on my block for the nnew fel pro head gaskets and reinstalling my heads.
what do you all recommend to use to clean it off? razor blade? shoot me what you think is best.
thanks.
Rick 91GT
Mustang Master
95
99
PA
Jul 4, 2006
  • Jul 4, 2006
Razor blade works fine just do not dig the surface scotch brite can also be used, then a final wipe down with brake clean.
BadAndy
766
Ohio
Jul 4, 2006
  • Jul 4, 2006
do you have an air compressor??
T
tbi92rs
69
Louisville, KY
Jul 6, 2006
  • Jul 6, 2006
yes i do
Blk91stang
607
North Brunswick, NJ
Jul 7, 2006
  • Jul 7, 2006
Angle Grinders work wonders. Forget that wussy scotch brite crap!!!
JK!!!
I always use a razor blade, my fingernail, and finally brake clean.
onebad7up
97
Nashville
Jul 7, 2006
  • Jul 7, 2006
If you use the angle grinder make sure you keep it flat so that you have an even surface.
R
R2D2
Jul 7, 2006
  • Jul 7, 2006
scotch brite
Blk91stang
607
North Brunswick, NJ
Jul 7, 2006
  • Jul 7, 2006
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
