delete for heater tubing under intake?
riceslayer302
Banned
Oct 3, 2006
CT
does anyone know of a kit that deletes the black heater tubing under the upper intake?
im finishing up my build and i have no heater core, so i would like to eliminate this tubing but idk if i need the engine coolant temp sensor that is on top of the tube. could i plug the holes in the lower intake that supply the tubing and put a reducer in to fit the engine coolant temp sensor?
If you are running EFI you will need to hook up the ECT sensor. What you can do is get a adaptor to fit in the intake and allow the senseor to screw in to it. If not just get a brass plug to eliminate the tube all together.
