Deleting A/C
dbdragracing
397
I just got the Ford Racing A/C delete kit that moves the power steering pump up. I have a few questions before I start this:
1. What all do I need to take out from behind the dash when deleting the A/C (dash is already apart due to black interior swap)?
2. What all needs to come out from under the hood?
2. Can I just unplug my climate controls with A/C and plug in the climate controls I got without A/C or do I need to rewire?
3. My kit didnt come with any instructions....I need some pics of this kit.
Thanks for any help.
You dont have to do any electrical work when you delete the A/C. Everything works you just dont have the refrigerant flowing through the lines.
Under the hood you take out the compressor and the lines that are attached to it. They unscrew on the passenger side firewall in that silver canister.
No rewiring. That is all.
What about a condenser? Is there anything inside the dash that sould be removed to completely get rid of the A/C? I was going to swap out climate controls for ones that don't even show the AC settings. Thanks.
If you don't want heater or blower, then you can remove the entire evap case and ducting. But be sure to cap off any vac lines. If you want to keep the heater or blower, then leave everything behind the dash.
All you need is a few wrenches. Make sure your ac is dischaged. Start taking off the two big black hoses connected to the condensor. Then what thats off get the condensor off just like 3 bolts. Then theres a few brackets. You need to unbolt the ps pump, not hard. The hard part is taking out the stud that goes into the block. Take a pair of vice grips, lock them on the stud and turn it, make sure you have some gloves on and itll come off. Then just put the new bracket on find the right belt and its that simple. Then unbolt the radiator, and push it foward. I forgot what its called but that radiator looking thing in front of the radiator needs to come out. Just hit it a few tmes till its lose it may have a bolt i dont think so, then make sure all the hoses are free and pull it out. If you want to take out the heater core while your in your dash you can but it will wont make a difference, just bypass it. Other then that nothing else is needed. Id suggest taking out the smog stuff too, few bolts you take out the pump, and plug the hose going to the heads. Taking out the ac and smog and the shortbelt gave me 2mph in the 1/4. Good luck let me know if you need pics oh and heres instructions to the kit.
http://store.summitracing.com/instructions.asp?File=fms-m8511-a50.pdf
dbdragracing said:
Thanks for the help guys. Will my stock belt work with the A/C eliminator? Do I need to get an eliminator kit for the smog pump? Thanks.
You will need a differnt belt, and it is a trail and error thing, honestly everyone on here that has eliminated a/c and smog runs a different size belt. Ive seen people run a 70.5" belt w/o ac and smog and i cant fit anything under 74" on mine.
And for the smog you wont need any kit. Just take off the like 3 bolts and it drops out, literally, dont be under the car when you take the last bolt out cause it will drop to the ground like a rock. After that just take out all the hoses and stuff, there should be a hose going to your exhaust pipe youll probably have to get that plugged, and also there is a metal hose going to the back of the ehads, you need to take that out and plug it. I ran it for a while without plugging the holes and didnt have a problem, just a horrible sound and i was told its hurts gas mileage. I just found a big bolt put it so the top covers the hole, and put duct tape around it so it dosent fall, that hose sucks in air, so itll be sucking the bolt, and when the car is off the tape keeps it there, ghetto but gt40ps are going on soon for me.
Do you have an o/r pipe though? I wouldnt suggest taking out the smog with cats on the car.
