So I am trying to get my 331 running right and I think I created a coolant flow issue. I'm working with a 91 331 stroker and I wanted to delete the A/C and heater. A/C was pretty straight forward. I am running the TrickFlow A/C delete kit which relocates the belt tensioner. To delete the cooling lines to the heater core I removed the two lines that run from the water pump to intake to firewall. I got an adapter to screw the sensor from the heater lines directly into the intake manifold and plugged off the outlet from the water pump where the line would normally attach. I hope this makes sense and you can follow what I did. Did I do this wrong? Should the water pump outlet still run to the lower manifold? I don't really know the direction of flow.
