Desktop Dyno
Thats cool I just want to play around with some different combinations, been seriously considering the v8 swap on my 2.3 so just wanted to know if I could get any accurate results from the software. thanks for the reply.
It doesn't work well for engines with power adders, but for a natrually aspired engine, it seems to be fairly accurate. I put in the numbers for my 2.3, and it came out real close, but you have to be very precise on cam specs, and head flow, ect.
I have it and find it to be quite good. Modeling some engine combos accurately can be a bit tricky at times.
...also have some of the add-ons to test your engines on drag strips etc. which can be fun to fiddle with if not eye opening once in awhile.
HD
Lx89Stang05 said:
i tryed it with my motor and i doesnt change if you put 10psi then 20psi it stays the same :shrug:
I had much the same problems. it dosnt seem to well setup for the 2.3.
which makes no sense since it is all mathmatically figured out. I was suprised they had the 2.3.
By now you could probly find it free somewhere on the net.
fun toy, and gives you a visuall idea of what certain things might do.
later,
turboflush
