I have a 302 with a pretty worn looking holley 600 sitting on top and I know it has to be shot...So I have this holley 750 double pumper sitting doing nothing and I know its too much of a carb for a 302 but is there a way that I could tune it down a bit to where it doesnt drown the motor out???
Jetting it down, simply leans out the mixture, making it worse for the motor. If all you want is a smaller carb, then simply disconnect the secondary linkage, this will in effect make it a 500 cfm, 2 bbl carb. the 750 DP has the same size throttle bores as the 500--2 bbl, (the 2 bbls are flow rated at a different pressure differential) and is jetted two sizes below the primary side of a 750. Change the jets from 75's ( if that's what's in there now) to 73's. The Holley lists some 750's as having #70 jets, in that case, you may need to jet up 2-3 sizes. If you want to fine tune it, then after doing this, you may need to change the jetting on the primary side. In doing so I usually go up or down 2 sizes at a time., depending on the need for such after reading the plugs.
