Detuning a Carb
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
I have a 302 with a pretty worn looking holley 600 sitting on top and I know it has to be shot...So I have this holley 750 double pumper sitting doing nothing and I know its too much of a carb for a 302 but is there a way that I could tune it down a bit to where it doesnt drown the motor out???
whats junk about the 600? PM 10secgoal he is more knowledgable about carbs than me but if they are the same models I would Pull everything off the mainbody from the 600 and put it on the 750 as well as the jets and that should get you close.
You CANNOT "jet down" a 750 to a 600.:rlaugh: Jetting it down, simply leans out the mixture, making it worse for the motor. If all you want is a smaller carb, then simply disconnect the secondary linkage, this will in effect make it a 500 cfm, 2 bbl carb. the 750 DP has the same size throttle bores as the 500--2 bbl, (the 2 bbls are flow rated at a different pressure differential) and is jetted two sizes below the primary side of a 750. Change the jets from 75's ( if that's what's in there now) to 73's. The Holley lists some 750's as having #70 jets, in that case, you may need to jet up 2-3 sizes. If you want to fine tune it, then after doing this, you may need to change the jetting on the primary side. In doing so I usually go up or down 2 sizes at a time., depending on the need for such after reading the plugs.
FordRacing302 said:
And since you say I just leaned out the mixture then cant I just adjust the air screw down and the fuel screw up a bit??
Don't understand carbs, do you?:D Those "jet" screws aren't jet screws, the only thing they do is affect the fuel mixture while the idle circuit is in operation. To affect the mixture off idle ( there's more than two circuits in a Holley carb, but we'll just concentrate on these two for now) you HAVE to change the jet screws inside the fuel bowls. The circuit this affects is the main metering circuit. :nice: Get a Holley carb book and read it, you'll find a lot of useful info there.:D
Ok Ok...Im sure the book would help me alot, but Im just gonna try to get by without spending any money...So I guess Ill pull the carb off change the jets back to normal and put the 750 back on there and deal with the bad gas mileage...The only thing I want is to see this car run
Just change the jets back to what they were ( should be73-75's or 70's if it's a -1,2 or 3 list number) , disconnect the secondary linkage, and enjoy. Those adjustable screws on either side of the main metering plate should be screwed in all the way, then back them out 1-1/2 full turns. There's an idle adjustment screw on the left side primary linkage, adjust this till it just starts to open the throttle blades. Start the motor, adjust the timing and then adjust the idle speed screw to where you want it, then fine tune the idle with the mixture screws.
Update: I took the 750 off again and replaced it with the original jets after that I had a buddy of mine come over and help drop the gas tank so I could empty out the old gas, The gas was dark brown...So we put it back in put some fresh gas in, sprayed some starting fluid down the carb and as soon as we turned it over it flamed out the carb...So what this means to me is I got good gas and obviously good spark but its not timed, but I went about timing it right
But while doing all this I ran into another problem, the car barely wants to turn over and my battery is at 12.7 volts...and everytime it tries to turn over the negative battery cable smokes at the battery...The car was turning over perfect a few days ago, I dont understand it
FordRacing302 said:
Well you shoulda spoke a little sooner:Damnit: ...I just got done pulling the old carb switching out the 2 jets and installing the 750...So your telling me this is going to be bad for my motor!!!
Wow, I feel terrible....it's all Stangnet's fault. Whadda shame.
