  • 1994 - 1995 Specific Tech
Diablo Chip woes
  • Thread starter Thread starter raven69david
  • Start date Start date Jul 31, 2004
raven69david
112
San Antonio, Texas
Jul 31, 2004
  • Jul 31, 2004
Got the chip back today, and the car won't even start now. As soon as you crank the car, it barely kicks over, sputters and then dies. It appears the car got flooded after 3 attempts to turn it on. I removed the chip and returned the computer to stock setting. The car took several cranks to kick over which made me a bit nervous at first. After turning on, the car ran the way it did before the install/uninstall of the chip.
I am now pretty much through with trying to tune my car with this chip. It would have been a great solution had it worked, however now i'm back to square one. The car does not run well at all as it needs to be tuned, however the tuner i've been referred to charges waaaaaaay too much $ for a dyno-tune, so i'm stuck with a blown Cobra with tons of potential now used as a to/from work vehicle. There is another tuner locally, however now i'm outta funds to play with the car. What to do, what to do?!@@#$@#@
Any suggestions?
R
rockin_rick
968
Jul 31, 2004
  • Jul 31, 2004
Did you try cleaning the ECM's circuit board well? Perhaps you are not getting a good connection.
Rick
raven69david
112
San Antonio, Texas
Jul 31, 2004
  • Jul 31, 2004
Yep, i tried that. Those things were cleaned out very good as described with the Diablosport instructions. I need to go a different direction now. This obviously will not solve my problem. twEECer, PMS or what?
NIN
452
moorhead MN
Jul 31, 2004
  • Jul 31, 2004
I had the same problem with a jms chip and I had to clean the port a couple of times. I really wanted to get my car running right. It still has a rough Idle when cold but doesn't die anymore, but gets close.
thanks,
tom
NIN
452
moorhead MN
Jul 31, 2004
  • Jul 31, 2004
P.S. What is a good tuner for the 94-95's. When I get my super I will need something to tune it and that chip will not do the trick unless reburned. don't like the idea of a undynoed chip.
thanks,
tom
R
rockin_rick
968
Aug 1, 2004
  • Aug 1, 2004
What the deal with this chip? (I don't know the story) Did you have this custom burnt for you and your setup?
I still vote for recleaning the J3 port. When I installed my TwEECer, I thought I had it cleaned off good enough, but didn't. That silicone coating is a b-i-t-c-h. It's worth a try, after all, it's free. Here's what I did to clean mine -
http://tweecer.oplnk.net/viewtopic.php?t=2877
Rick
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Help - SCT Woes
  • James banks
  • Jan 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
