Diablo Predator
If you are not going to do a lot of modifications to your car other than exhaust or something else minor, then yes the Hypertech Power Programmer is the most bang for the buck... you get over 50 extra horses when you use it on a stock cobra... it also has two additional tuning programs in it... one for a 3.0 inch pulley and one for a 2.8 inch pulley (+64 horses with the 3.0 and +76 horses with the 2.8 and +96 ft/lbs of torque)!!
I like the predator better. Look at what this thing can do.
· Timing Table (+/- 10%)
· Fuel Table (+/- 15%)
· Idle (+/- 20%)
· On/Off switch for Traction Control/Rear 02 Sensors (Off-road Exh)
· Speed Limiter
· Rev Limiter
· Part and Full Throttle Shift Points
· Shift Timing
· Shift Pressure
· Re-Calibrate Speedometer for Gear and Tire Size Changes
