Do I have to get a dyno tune if I want a reburn on a Diablo Rev. chip or can I just send it in with a list of my mods to get the reburn and install it without it being on the dyno.
squares98 said:you dont need a dyno tune,Your local cmr-dealer or dyno tuner can reflash your chip with out using the dyno to your paper specs..
propellerhead said:Look at it this way... You can send your suit in to get it tailored. Just tell them you gained 50 lbs and 2 inches taller. They can adjust the suit pretty good. Or, you can go to the tailor and have him measure you and adjust the suit based on that.
The first option is cheaper and pretty good if you go with a reputable tuner. They've been doing this for years and can hit it pretty dead on usually. The second option costs more but will be more accurate.
NickDiabloSport said:You could always just go the Predator instead of a chip, now you can make the gear change when need be, fine tune the calibration as needed including the transmission, have full diagnostic features, data monitoring and logging capabilities.
The Predator cost is higher then a chip but the flexability if offers and added features make it the best value.
Thanks,
Nick Spinelli
DiabloSport Sales Manager
