Okay, I have posted this issue kinda before but I wll post it one more time because something new has propagated...all help is appreciated.
1.) Car idles really really weird ever since my intake install. Its kinda like a rythmic beat, and the car shakes...you can especially feel this at low low speed and sitting at a stoplight.
2.) The low oil light came on today and I was down prolly about 1.5-2 qts. Its been 3500 miles since my last oil change. Its never burned oil before...there is no smoke, there was no coolant in the oil, no oil in the coolant etc...
3.) City gas mileage is down from 17ish mpg to about 13.
4.) Car sometimes dies when put into D or R (AOD-E)
The car as about 112k on the clock. Intake swap very recently but it seemed to go really well.
I am also having an issue with the transmission that I have attributed to the neutral safety switch (MLPS) which I am replacing tommorow but I don't think that has much to do with it. All its causing is the car to downshift randomly, sometimes all the way to neutral (maybe causing bad gas mileage?)
Its really hot here, triple digits most the time and quite humid, dunno if that has anything to do with it.
I do get engine codes for the thermactor air control system and I have questioned whether or not by cats could be clogged up nicely.
I plan full tune up tommorow or the next day depending upon when I get the MLPS finished (plugs, wires, cap and rotor) I run 89 octane because I ping with the lower stuff. Also plan to clean the IAC and the like.
Couple of things I was thinking were that the little thingamajig (sorry I dunno what its called) that plugs in to the lower intake in the back sits pretty loose and might not be working (maybe thats the PCV?), some of the plug wires are not seperated very well and may be arcing, the idle may be set wrong and that may cause a lot of fuel burn, and the distributor may have been reinstalled just slightly off.
Anyway, I need this car it is my transportation to school and my DD. School is 1,000 miles away and I am leaving soon so I want to check EVERY possibility. The car is stil fairly new to me and I have no idea about the maintenance record before I got it. All help is appreciated, I check this board almost hourly so feel free to ask questions or for pictures, or even sound clip maybe.
Sorry so long, thanks for your time!
not good..The screen will help slow it down some...but wont cure a baffle missing...
