I've been getting a Check Engine light on when I'm driving lately. At first, it seemed correlated to me running the car low on gas. However, the other day it did it with a half tank, and the light would not go out any time I put load on the engine. So, I went into Autozone and borrowed their EEC-IV code puller...
I did a KOEO test, and got this:
Code 11
Code 32
Code 11 I guess is a normal everything's ok code...but code 32..according to Autozone, doesn't exist. And I know how to read codes, I've done it before. It WAS a code 32.
I also did a KOER test, and got:
Code 41
Code 91
Both O2's reading fixed lean. Now, I'm running lots of mods, and have an AFPR that WAS set to 42 psi (w/ vacuum). I decided, however, to bump it to 45 psi to see what happened. Well, the car now runs PIG RICH and has ZERO power... Makes a big stink at idle....and a KOER test STILL reads both O2's as lean. This is definitely not correct. So, what could be causing my nonexistent codes, and false lean readings? I know the false lean could be fouled O2's....but, both of them, at the same time, when they have a MAX of 20,000 miles on them? I checked for vacuum leaks already, and I have none. My MAF is aftermarket and in good shape....I clean it regularly (the K&N filter's oil gets on it and fudges the signal up)
And, can anybody shed some light on the Code 32 deal? I'm lost here. I throw a check engine light, and then the computer gives me a code that doesnt exist... The computer says I'm always running lean.... I'm beginning to think the computer is just malfunctioning.
Thanks everyone. I'm on the verge of ripping it out and doing a carbed conversion. Arrrrr
Code 11
Code 32
Code 41
Code 91
