Diagnostics Help....Tran,engine,cooling
Makdaddymac
323
orlando
Ok, this is tranny/engine related......
1st)Just within the other day. With no oter signs of leadings towards problems..My tranny is acting funny, it isnt clicking and claiking(yet) but when you put it in second and let off the clutch the shifter handle pulls/wobles to the right kinda diagnal, in third it pulls wobbles to the left . 4th is ok but i shift into it at like 2k cause im scared of getting on this thing. 2nd and 3rd are giving me the most trouble...I had someone drive it and they said they were halling ass in it and it was fine but its my car and i know somethings either going,gone,or a little of both................
2nd) my low coolant light keeps coming on,i filled it to the cold line on the overfill tank and drove it.
when i got to work it overflowed out the overfill plastic crappy tank,all over the place...No leaks? Possible water pump failure???,i changed the raditor cap from a 13lbs to a 16lbs it helped,well i think it did.but im in the same boat...i pull the cap when its cold and its full in the radiator but i dont know...Im more worried about the tranny right now...
3rd) along with the 1st being my critical problem the cars starts surging and the check engine light comes on. i got codes 66,95,85,87 which are all fuel pump related...One which i might not have included is MAF and tranny temp sensor(im not sure if thats right)..
Thanks guys any ideas is apprciate....:nice:
The coolant light isn't connected to the computer, so you can ignore it if it doesn't work correctly.
There is no temp sensor for the transmission.
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Code 87 – fuel pump primary circuit failure. The fuel pump lost power while the engine was running. Check fuel pump relay, check inertia switch, wiring to/from inertia switch, red wire going to inertia switch for +12volts. Check the other side of inertia switch for +12 volts.
To help troubleshoot the 87 code, follow this link for a wiring diagram for 89-93 cars http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp
For 79-88 cars use, http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp
Code 95 - the 95 code is because at one time or another the fuel pump relay hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition.
To help troubleshoot the 95 code, follow this link for a wiring diagram http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
Using the diagram, check the red/black wire from the fuel pump relay: you should see 12 volts or so. If not, check the inertia switch: on a hatch it is on the drivers side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. No voltage there, check the Orange/lt blue wire, it is the power feed to the fuel pump relay & has a fuse link in it. Good voltage there & at the Pink/black wire, swap the relay.
im more worried about the tranny...???but i guess if it aint broke dont fix it...
I dont know if it helps but the car excep the tranny part will run good for about 10-20mins then the check e light comes on it starts sputtering etc...
As far as the codes go.
code-66 i cleaned it out of boredom about a month ago and that might be the reason its messing up. I can try to clean it again.If not i'll replace but not before cleaning it and diagnosing the other problems which might be a cheaper fix...
85 is there a way to replace these canp cause the part store dont have one,or a part number...
87- MY inertia switch is missing the lil black box thing was ripped out i guess(i cant find even a trace of were it was ripped).Do i need to have one it ran fine w/out it for as long as ive had the car...which is about 6 months now
95- also is it possible this thing is messed up,i oculd replace it cause its probably cheap.Is the one located under the drivers seat???
The inertia switch shuts off the fuel if you get in a collision. It is supposed to help keep the car from burning to the ground if there is a fire after the collision. Coupe & hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch.
The fuel pump relay will be under the driver's seat. As with all code generated items, don throw parts at it, do some troubleshooting. You will save time and money.
The carbon canister solenoid & plumbing are junkyard items.
The carbon canister vents fuel vapor into the intake manifold at cruse. This helps richen up the cruse mixture slightly. It also eliminates the gas stink when the car is closed up in the garage or other poorly ventilated place. Don’t park you car in the garage if you have a gas fired water heater, the fuel vapors are a potential explosive hazard.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
If you have emissions testing in your area, plan on re-connecting it. You won't pass the visual inspection without it.
