Did I break it?
Hey Gents,
I'm installing my headers and as part of the process I removed the dip stick tube. I've been trying to reinstall it with no luck. I'm about ready to toss a lit match at the car!
When I removed the dipstick tube, I wiggled it out and it came out with ease. but now I can't get it back in.
Please take a look below with what I have left.....oh and while it was out, i decided to freshen it up by repainting it.
Sorry for the small pic, i took it with my BB
i did the same damn thing when i put my shorties on. just yanked right out. you didnt break anything, it just sucks to try to find the little damn hole :bang:
I hate to say it but it could be broken. I have a dipstick from a 1993 T-bird. It has the double rings or flanges on the tube. I measured the T-bird dipstick tube and the entire length of the tube was 17 3/4". That is measuring tip to tip not along the length of the tube. The length of tube below the second ring is 2 1/2" So if your tube lenght is 15 1/2" you might have a problem. FYI the T-bird tube had two diameters below the second ring. The part that fit into the block was the diameter of of the tube above the block but the last 1 1/2" (the part of the tube closest to the oil in the oil pan) is smaller in diameter. I mention this because: if the tube is broke and you try to extract it you could push the broken part down into the oil pan.
Also the T-bird dip stick had a "T" handle that has ENGINE OIL written on it. Most of the Mustangs dipsticks have the yellow loop type handle. IIRC the Mustangs dipsticks has an "O" ring on them ,the T-bird dipstick does not. I hope this helps
Hey Guys,
Guess what....i did break it. after trying to get it in for about an hour, I realized there was a piece inside, the second ring. I extracted it with a an extractor bit and bought a new ford racing one that is pictured above with the two rings.. man what a learning experience!
Getting the new one in was a real PITA!!! I ended up buying a crows foot socket set and used the 7/16 foot socket and tapped it in with an extention! That took me another hour or so to figure that out!
thanks everyone for your feedback! as always you guys rock!
