  • SN95 4.6L Mustang Tech
Did I break my COP?
  • Thread starter Thread starter 89lxsport50
  • Start date Start date Jun 17, 2006
89lxsport50
550
Franklin Tennessee
Jun 17, 2006
  • Jun 17, 2006
Well, I decided to make sure the plugs were tight in my new 02GT. When I removed one of the COPs the boot stayed on the plug, and I was left holding the coil with a long spring sticking out of it. This suprised me to say the least. I stuck it back in, and the car runs fine. No cel, no misfire. Is it normal for them to come apart like that, or did it break?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 17, 2006
  • Jun 17, 2006
You should have pulled the rubber boot out and re-attached it to the COP well. It is probably not in there just right at the moment. I suggest you pull it again.
And as long as you are in there...
What I do is take all the rubber boots off the COPs, the boots that cover the spring that connects the COP to the plug.
Then I put them all in a bucket of warm soapy water and slosh it around and clean them thoroughly.
Then I dry them.
Then I coat each one of them well, inside and out, with silicone spray.
Finally I put a nice dab of silicone dielectric grease on each end of the spring and put it all back together.
When I pull my COPs they come off super easy and make a cork-popping sound cause they all have a rock solid seal
89lxsport50
550
Franklin Tennessee
Jun 17, 2006
  • Jun 17, 2006
Thanks man, I'm new to the 4.6 engines. I thought I had broken it. I was very suprised that the car fired right up and ran with no problems. I will pull it again and properly re-attach the boot. Thanks for the advice.
RedBullitt
462
Morgantown WV
Jun 17, 2006
  • Jun 17, 2006
definately be generous with the di electric grease on the springs etc. the seals should be good like he said. you will be set
89lxsport50
550
Franklin Tennessee
Jun 17, 2006
  • Jun 17, 2006
The thing that suprises me the most is there is no hard connection between the spring and the metal part that attaches to the plug. I would have thought it would have been conected.
damacman
529
Phoenix, AZ
Jun 18, 2006
  • Jun 18, 2006
When you're talking 10,000 or so volts and a few milliamps you can get away with these types of connections.
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • brandyn200
  • Jun 20, 2026
AeroCoupe
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
