A couple of months ago when I installed my cams I was reinstalling the crank pulley. The bolt was too short to reach the threads so I got my old UD pulley bolt, since it was longer, put the washer on and cinched the pulley down then put the regular bolt on. Guess where I found the crank washer? Still on the UD bolt in my junk bin.
I was pulling the crank off today to determine a clackity noise that I thought was coming from the timing chain and found the screw up. The crank pulley was on pretty good because I still had to turn the pulley puller pretty good to remove it but there was probably some movement during operation (and several runs at the track).
My question is did I screw up the main bearing if the crank wasn't on tight? What kind of sound would a bad main bearing make if it were bad?
Dammit...
Dammit...
well i had to tear everything down again, & do it ALL over
funny now, but i about cried then, lol
