94 Cobra former daily driver now driven less than 1k a year, 42k miles, bone stock except for K&N filter, near perfect condition if you don't consider that it won't start.
I drove it a few weeks ago after sitting for a month. Started fine and ran perfect for 7 miles. Stopped for about 45min then headed home.
3 miles from home I ran medium acceleration through 1st gear, shift to second and hold it on the floor till @5500rpm pulling smooth and strong the whole time. Then let off, slow down and continue at 45mph 4th gear. 1 mile to go engine starts chugging as if running out of gas or having elec problem. It would run at minimum throttle but bog if I tried to accelerate. I turn into the neighborhood and it dies and will not start.
Before I found the checklist I did these things (not in order)
Listened for fuel pump, sounds normal and sprays out of valve near throttle body.
Replaced fuel filter.
Added two gallons of fresh fuel to verify gauge is working. Fuel in it was not old.
Distributor is tight
Unplug MAF sensor
Hold throttle at all different positions
Spray either into throttle body
Test injectors with noid light
Check for good spark at plug
Cleaned IAC with carb cleaner
Checked inertia switch
Disconnect neg battery cable for awhile
Now that I found the checklist do I need to do all that stuff if I have good spark and seemingly good fuel pressure? Thanks.
Unplug MAF sensor
