Diff Bushings.......Porta-Power?
TrophyHead
1,195
11
49
PA
I'm changing out my differential bushings. The MM tool is garbage. I stripped the threads on the bolt. I have another 1/4 inch to go. It's going in straight as an arrow.
Do they sell some sort of porta-power to press this bushing into place?
I'm pretty pissed off about this goofy MM bushing removal tool. First off why the hell is it fine thread. And there instructions suck.
I'm wrenching the balls off this bushing and I'm worried about breaking the cast iron ears. Any idea's?
Edit: I used a die-grinder to clean up the inside of the ears. I'm also sparying WD-40 while trying to press it in.
I used a socket the same size of the bushing and a 3lbs sledge. Lube it up with some WD-40 as you said and tap tap taparoo.... My problem was getting the old ones out. I went out and bought a cheap air hammer. 2 seconds of work once I had that. :D
