  • SN95 4.6L Mustang Tech
Diff fluid leaking onto passenger wheel?
  • Thread starter Thread starter OneStiffGT
  • Start date Start date May 24, 2007
1 of 2 Next Last
O
OneStiffGT
87
Canada
May 24, 2007
  • May 24, 2007
The other day I was washing the car and I spotted a leak on my wheels, first I thought it was break fluid then I realised it is diff fluid.
What does this mean? It is leaking jsut iinside the wheel? I've got 31 spline moser axles if it makes any difference.
Axle Seals?
C
chuck943
262
north carolina
May 24, 2007
  • May 24, 2007
Yes that is a leaking axle seal
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 24, 2007
  • May 24, 2007
Could also be grease from a shot wheel bearing.
O
OneStiffGT
87
Canada
May 24, 2007
  • May 24, 2007
Smells definitely like diff fluid.
In this case, do I need a complete new axle or just a seal?
C
chuck943
262
north carolina
May 24, 2007
  • May 24, 2007
unless you are running independent rear suspension your axle bearings are lubed by the rear diff. fluid, not grease. Unless the bearing is moving on the axle(it is pressed fit) or you have a groove worn in the axle from the seal then axle should be ok and seal replacement should fix it.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
May 24, 2007
  • May 24, 2007
seal is bad. its an easy fix
Twisted
387
Hansen,CT
Sep 6, 2007
  • Sep 6, 2007
If you change the axle seals do you need to add additional fluid above the normal 2 quarts?
BennyBlown2v
1,233
Carmel, INdiana
Sep 6, 2007
  • Sep 6, 2007
You need a new axle seal - it's not a difficult install.
1) remove diff cover draining fluid
2) remove pinion cross shaft (small bolt and slide shaft out)
3) remove U-clip ("c" clip) from axle by pushing axle in and sliding clip out
4) remove axle from rear end (pull)
5) use slide hammer w/ attachment to pull out axle seal
6) use seal driver to install new seal
7) go backwards and re-install everything, don't forget to put new fluid and friction modifier in!
Twisted
387
Hansen,CT
Sep 6, 2007
  • Sep 6, 2007
How much fluid? 2 quarts or more. I have dealer charging me 4 quarts for an axle seal replacement job. They claim they needed to refill the axle tubes.
RandyStinchcomb
1,159
Randallstown, Md
Sep 6, 2007
#10
  • Sep 6, 2007
  • #10
thats total BS, rear dif only holds something like 2.4 qts and that includes a 4 fl/oz bottle of friction modifier, you dont fill the axle tubes your dealer got you on that 1
Twisted
387
Hansen,CT
Sep 6, 2007
#11
  • Sep 6, 2007
  • #11
I'm fighting them on it and I need some proof. I have the Ford Workshop Manual and it says nothing about extra fluid. Just the fill to 1/4-9/16" below the fill hole. That is where the service manager is claiming 4 quarts.
R.J.
813
Warwick, Rhode Island
Sep 6, 2007
#12
  • Sep 6, 2007
  • #12
The Haynes manual says 3.75 pints, which is almost 2qts. Not even two full qts!!
If they used 4 qts, thats why it is leaking out!!
BobHyatt
378
#13
  • Sep 6, 2007
  • #13
one other step to add. If you have ABS, remove the abs sensor on that side, otherwise you can't push the axle in far enough to remove the c-clip.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Sep 6, 2007
#14
  • Sep 6, 2007
  • #14
I have my rear end bench rebuilt recently and it was throwing fluid out of the breather because they over filled it. If you can get your car level on jack stands, pull the drain plug and see what comes out. If fluid comes out it may just be over filled. If not then it provably is the axle seal.
Did they already do the service on the car ?
BennyBlown2v
1,233
Carmel, INdiana
Sep 6, 2007
#15
  • Sep 6, 2007
  • #15
Good point! Also, when removing the sensor always remember to ROTATE it to get it out of the hole, and when putting it back in do NOT over tighten it or the plastic will crack, very easily.
That's TOTAL BS that it takes 4qts! You should only have like 1.78qt in there or something. The axle tubes don't need "filled", its one continuous cavity (the center section and axle tubes).
BobHyatt
378
#16
  • Sep 6, 2007
  • #16
Some idiot saw 3.76 pints or whatever it says, and didn't realize that was not the same thing as "quarts". I'd suspect simple error rather than a ripoff, as it is too easy to verify the correct amount and they then come up looking like thieves...
Twisted
387
Hansen,CT
Sep 7, 2007
#17
  • Sep 7, 2007
  • #17
Here is what the service manager is claiming.
"we did axle seals in your vehicle. This means we have to fill the center section and the axle tubes. The axle bearings are lubricated by the gear oil. The entire axle housing was empty due to the fact the axle seals had to be replaced. The amount of fluid charged is the amount used."
4 quarts my ass. I am now trying to get a hold of someone higher than him at the dealership.
RandyStinchcomb
1,159
Randallstown, Md
Sep 7, 2007
#18
  • Sep 7, 2007
  • #18
the axle tube(s) Do Not Need to be filled.
the 2 qts of fluid in the center section will flow out into the tubes and lube the bearings.
this service manager is full of it.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 7, 2007
#19
  • Sep 7, 2007
  • #19
They probably just confused pints with quarts which would mean they put twice as much in as required since there are two pints in one quart...
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 7, 2007
#20
  • Sep 7, 2007
  • #20
Axle seal at the end of the tube.
1 of 2 Next Last
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
