  • SN95 4.6L Mustang Tech
Differences between subframe connectors
  • Thread starter Thread starter Gatorman1369
  • Start date Start date Jan 14, 2004
1 of 2 Next Last
Gatorman1369
61
Gainesville, Florida
Jan 14, 2004
  • Jan 14, 2004
I apoligize in advanced in case this has already been discussed a billion times.
I have a 03 GT Vert and I would like to stiffen up the chassis a bit. I noticed that I have bolt-on connectors already. Browsing CR Motorsports' website I noticed basically two types of subframe connectors that I can purchase. Well 3 but I want the Alloy, not the mild steel (unless there isn't a justification in spending more money for alloy).
1. Steeda Subframe Connectors 94-03, except 96-98 Cobra, 4130 Alloy, Weld In
Code: 555-5320
Price: $102.99
2. Steeda Full Length Sub Frame Connectors
Code: 555-5245
Price: $117.99
Can somebody enlighten me as to which ones I should purchse? I want to make the right desicion the first time around because of them being welded in.
Thank you.
mogs01gt
3,113
30
119
Ohio
Jan 14, 2004
  • Jan 14, 2004
weld ins
Red00vert
39
Hampton,GA
Jan 14, 2004
  • Jan 14, 2004
Don't change them...just get new lowering springs. Or bigger wheel/lower profile tires. That should help alot.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Jan 14, 2004
  • Jan 14, 2004
Weld-ins for sure. I selected Griggs. They did some testing on the length of the SFC's and determined at what point extending them any further would be of no more help. Then they decided to make that size only. Good luck, SFC's are a very effective and reasonabily priced mod.
D
DC-GT
312
  • Jan 14, 2004
SFC's are definately a good mod. Metcos are highly recomended where I am but you will pay more for them. The Steeda SFCs have additional torque box support. To me that is a very good thing if you plan on launching hard... When I finish my engine mods I will be looking at one of these two...
Bo
mogs01gt
3,113
30
119
Ohio
Jan 14, 2004
  • Jan 14, 2004
please dont give out bad advice. Subframe connectors are a VERY VERY good mod for any car. It helps with more things than just handling.
Gatorman1369
61
Jan 14, 2004
  • Jan 14, 2004
Right, I know that they are a good mod. I guess I need to now ask what the difference is between the regular and full length. another words, is it worth doing the full length and will I be shorting myself any with the regular ones....know what I mean Vern...
NasaGT
1,993
Virginia
Jan 14, 2004
  • Jan 14, 2004
The full length are well worth it. I put Maximum Motorsports full lengths on my vert, and the difference was unbeleivable. The car is firm, no twisting or flexing.
hognutz
1,940
albany, oregon
Jan 14, 2004
  • Jan 14, 2004
I would check out globalwest.net they have some tubular ones that I think I am going to get. You definatly want weld in. I would get the full lenght.
mike2858
1,456
West Long Branch Jersey.
Jan 14, 2004
#10
  • Jan 14, 2004
  • #10
get the full length ones.
Gatorman1369
61
Jan 14, 2004
#11
  • Jan 14, 2004
  • #11
Thank you very much gentlemen for your quick responses.
edit: I just read about rectanglular vs. tubular....crap, I thought I had it settled. Any Adv/Dis between the two?
bird
342
Garden City, NY
Jan 18, 2004
#12
  • Jan 18, 2004
  • #12
Code: 555-5320
Price: $102.99
Code: 555-5245
Price: $117.99
Thank you.
IMO, Griggs subframe connectors----> $89.95 Save your money.
LI98GTStang
1,715
L.I., NY
Jan 19, 2004
#13
  • Jan 19, 2004
  • #13
As you already know, by the description the second one is full length, which offers more strength. But I think a major difference between the two besides length is the weight. The 4130 Alloy is going to be quite a bit lighter than the full length ones, and you also would probably add the seat cross brace to the 4130. I believe the 4130 is going to need to be TIG welded, which might make it more difficult to find someone to install.
IMO, if it's a daily driver and sees only occasional track usage, get the griggs or Steeda 4130 molly and save the weight with the Steeda's. If you do a lot of Launches at the track then the full lenghth would be the ones to go with.
K
kennym01
343
#14
  • Jan 19, 2004
  • #14
My feeling exactly, maximum motor sports is another good source for sub frame connectors. I have a convertible also and I will be doing this mod sometime soon.
01SLVRGT
201
Macon Georgia
Jan 19, 2004
#15
  • Jan 19, 2004
  • #15
I've been very happy with my full length Maximum Motorsports connectors
Dale Royster
558
Canton, Michigan
Jan 19, 2004
#16
  • Jan 19, 2004
  • #16
Ive got the Chrome moly steeda sfc's on my car and I was amazed at how much of a difference they made in my convertible. Round tube is stronger then square tube, so I went with those. Not to mention they are lighter then normal mild steel.
Gatorman1369
61
Jan 19, 2004
#17
  • Jan 19, 2004
  • #17
You guys are awsome. Thanks again for your time.
H
Hoppy
329
L.A. CA
Jan 19, 2004
#18
  • Jan 19, 2004
  • #18
Check into the Global West subframe connectors with the rocker rail support.
I made the purchase and am 100% satisfied. I would go with the individual pieces rather than the assembled kit (for the reason of differences in the fabrication jig and your floor pan)
Go tubular, as they offer all the support of the rectangular one but offer additional torsional rigidity (what shape stock do roll bars/cages come in?).
They don't hang low on the car....the mufflers will still be the lowest thing so there won't be any clearance problems.
Global West
Hop
Check the signature for links to my pics and you can see them installed
NasaGT
1,993
Virginia
Jan 20, 2004
#19
  • Jan 20, 2004
  • #19
As Hoppy described, the tubular gives you better torsional strength. But some tubular subframes are not jackable. That was what swayed me to the rectangular MMs. Space is tight under there, I wanted to be able to use them as jack locations.
Good luck!
85MustGT
95
Occupied San Diego
Jan 20, 2004
#20
  • Jan 20, 2004
  • #20
Max Motorsports offers SFC with the seat brace already installed.
1 of 2 Next Last
  • Locked
Expired 01 Cobra Fully Built 5.0 Stroker Socal
  • Doc Hawk
  • Feb 18, 2016
4K
SN95 Mustangs For Sale (1994-04) Feb 18, 2016
Doc Hawk
C
  • Locked
Steeda Subframe Connectors, Zinc plated, NEW 555-5245
  • clarkjr
  • Sep 24, 2011
  • Suspension Parts
2K
Suspension Parts Sep 30, 2011
clarkjr
C
Pics - Before and After V2 install etc
  • screamin gt
  • Apr 26, 2011
4K
1996 - 2004 SN95 Mustang -General/Talk- Apr 27, 2011
Dark04GT
D
Will these subframe connectors do the job? How does this gear install sound?
  • dstang01
  • May 27, 2008
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 28, 2008
toyman
T
Building my 2 valve.. have a few questions..
  • Trav4011
  • May 27, 2007
SN95 4.6L Mustang Tech May 27, 2007
TweekedGT
