Different? Idle Question
  • Thread starter Thread starter smac61
  • Start date Start date Mar 19, 2004
smac61
294
SC
Mar 19, 2004
  • Mar 19, 2004
I tried search but no luck. I have a problem a little different than those I have seen on the board. Normally I have no idle issues. Lately on cold start, I get very minor fluctuations, around 50 RPM if I had to guess. If I drive for 30 minutes or so, then shut it off and restart it 15 minutes later, I get fluctuations around 500 RPM, and most times it dies. Sometimes it starts jumping around if I have to sit at a long traffic light. I have to monkey with the gas pedal to get it to smooth out.
I have cleaned the IAB, checked the TPS (.95-.96), and I have the idle adjuster plate. No engine codes. I have found no obvious vacuum leaks, although I am suspicious of the line from the charcoal canister to the intake.
Anybody have a clue?
sublime29
110
  • Mar 19, 2004
Hello! I would guess it would be the throttle body not adjusted properly.The idle is not adjustable on the 5.0.The screw on the throttle body is a throttle stop screw.It prevents the blade from gettin stuck.It should be closed and adjusted so the throttle can be floored let off fast and close without gettin stuck at all but not lettin air by.Then check the TPS voltage.Then check timing and vaccum.Try to get some throotle body cleaner and clean out the throttle body and spray in the idle bypass valve real good. Later Sub
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
