Different years, different harnesses?
  • Thread starter Thread starter NOSNotch
  • Start date Start date May 31, 2006
NOSNotch
577
South Jersey
May 31, 2006
  • May 31, 2006
whats up guys. i tried searching a couple different times and havent really found what i'm lookin for. i'm slowly tryin to gather everything for my 93 to swap it back to EFI and currently trying to find the main harness, injector, and o2 harnesses. my question is what year harness do i need or is it strictly 93? also are the injector and 02 harnesses the same 86-93? thanks
kevin
vristang
4,933
101
124
Seattle
May 31, 2006
  • May 31, 2006
There are some minor variations in the wiring harnesses.
For example my 90GT actually has a 91 harness. So far as I could tell the pin locations are the same but a few of the wire colors changed. I think it was the ACT that gave me trouble.
A Chiltons should get you going in the right direction.
Courtesy of a jrichker post -
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiBr...3d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiBr...3d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiBr...3d801ddb3c.jsp for 94-98 model Mustangs
Good Luck
jason
C
coming4you
32
Toms river NJ
May 31, 2006
  • May 31, 2006
yeah
i have a complete 92 mass air eec ( computer harness ) sitting in my garage that i bought to use in an 88 and unfortunatly it wont work in my car.. I did end up getting an 89 so i have this one if you looking for one..
i have the harness ill take 75
and i have a a9l computer for a 100 if you want any of this im also in jersey
toms river
M
mustang30212
51
SouthEast
May 31, 2006
  • May 31, 2006
The 93 harness is unique to 93 model cars. The fuel relay us under the hood and part of the main harness. You will need one from a 93 model car.
I have an o2 harness and injector harness...they're the same from 87-93.
Lemme know if you want them...I can email you some pics.
RH
vristang
4,933
101
124
Seattle
May 31, 2006
  • May 31, 2006
I have been under the impression that any of these harnesses could be re-pinned to any ecu.
If this is the case then any harness could be made to work.
If you don't want to mess with moving wires in the harness, then buying a harness specific to your ecu is the best bet.
Is there any reason not to repin the harness?
jason
M
mustang30212
51
SouthEast
May 31, 2006
  • May 31, 2006
The 89 Harness is a non airbag harness. Different plugs at the cowl by the ecu test port. Also the afore mentioned addition of the fuel pump relay to the main harness on the 93. 90 Models are different also and require moving some plugs to make work. 91 and 92's are pretty much interchangeable.
Repinning the harness is a pain..and if you get one in the wrong place...you're looking for a new ecu.
Hope this helps.
RH
NOSNotch
577
South Jersey
May 31, 2006
  • May 31, 2006
thanks for the replies guys, i think i may have found one over on another site. including 02 and injector harnesses. thanks for the offer on the last two RH, i will let ya know if this other one falls thru. thanks
vristang
4,933
101
124
Seattle
Jun 1, 2006
  • Jun 1, 2006
Hope this helps.
RH
That's some good info.
thanks for taking the time to school me.
jason
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 1, 2006
  • Jun 1, 2006
Copied From bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Computers from 89-92 are all the same. Look for the A9L sticker on the back cover for a 5 speed that matches your requirements. Example: E9ZF 12A650 AA" with the A9L code.
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
  • Locked
93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 28, 2025
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
