Differental oil?
80-90 with a tube of standard parts store Limited-Slip additive.
Just a note, if you don't have an aftermarket girdle cover with the fill hole in it, you might want to mix the additive and some gear oil in a small oil bottle to pump it in ... the factory fill plug is not the easiest to get to without spilling half the additive all over the fill area ....
First hand experience :bang:
Dont use dino gear oil! That friction modifier stinks so intensely it will curl the paint off the walls. It's like pinetree sweat burnt oil.
Use synthetic 75w-90. It doesnt need friction modifier and even if it gives you 1% extra economy from reduced friction, it will pay for itself very fast.
You can also fill through the axle vent on the P/S as it is alot easier to get to than the factory fill hole.
89MustangGX said:
Only question I have is how you will know when it's full. :shrug:
I think he does it like people do trans filling (when filling through the shifter base itself). Remove the filler plug and pour through the vent till it starts seeping out the real filler plug. :)
I use Amsoil 75W90. Its $7.90 Sythetic Gear Oil and has the friction modifier in it. 4 oz friction modifier would be a good idea in non-synthetic gear oil. A little less than 3 bottles will be needed for the gear oil change.
