Differential Fluid
D-BOI
596
Metro Detro
Hey guys i have a 97 gt manual with 82k on the odometer and i wanted to do a differential fluind change on it. What type of oil to use? and if there is anything i should know before i start. Thanx in advance
I use Royal Purple. It has the friction modifier for the limited slip added to it. I think I used 74/145 but check your manual to see what weight you need. There should be a tag on the rear end cover that tells your gear ratio and weight of oil to use. That's what my 02 GT has on it. Pearl02.
