  • 1994 - 1995 Specific Tech
Differential ID Question
  • Thread starter Thread starter Chronos[AsG]
  • Start date Start date Feb 9, 2004
C
Chronos[AsG]
86
NC
Feb 9, 2004
  • Feb 9, 2004
Hey, I've posted before asking about what type of differential is in my 94 GT. I have another question now, though. Is there any way I can actually check and make sure what I have without actually opening up the differential? Due to some recent experiences in inclement weather my friend thinks I may not actually have a limited-slip differential. He suggested that since I bought it used that maybe someone opened it up and took out the clutch packs before I bought it. So again, is there any way I can test it? Any ideas would be appreciated. Thanks!
Justin
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Feb 9, 2004
  • Feb 9, 2004
It's almost certain that you have a limited slip (trac-lok) differential, but it's likely that the clutches are worn after 10 years of use, and it probably doesn't function well as one any more. Have it rebuilt when you put in new gears .
Dave
go-stang5.0
2,244
Glenview,Il
Feb 9, 2004
  • Feb 9, 2004
Hairy Canary is probably right. After 10 yrs its about time. However if you want to test it, do a smoky burnout and have a friend watch both rear tires. If one smokes and the other doesn't (or smokes significantly less, then its time to rebuild).
JETHRO
410
ALTOONA PA
Feb 9, 2004
  • Feb 9, 2004
jack the back up and see if both wheels spin the same way. they more than likely will. all gts have trakloc. clutch kit is about 45 bucks
P
PRO50SC
1,012
Olney, Maryland
Feb 9, 2004
  • Feb 9, 2004
There should be a metal tag bolted to the diff housing cover with a bunch of #'s on it. Write down the #'s and call the dealer. They will be able to tell you what it is.
Black70Fastback
319
Dyer, IN
Feb 9, 2004
  • Feb 9, 2004
if the tag is still on the rearend, it probably has not been apart. i myself never put the tag back on when i take a rearend apart b/c the info is incorrect after that anyway.
if its still there, the first few numbers will look like this
2 L 73 - thats 2.73:1 gear and the L means its a tracion lok
3 L 08 - 3.08 traction loc and so on.
id be pretty sure its a locker just wore out.
C
Chronos[AsG]
86
NC
Feb 9, 2004
  • Feb 9, 2004
Great! Thanks guys. I'll take a look at it later, but my friend said he'd help me replace the clutches when it gets a little warmer. Thanks for the info!
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
LT header id
  • djj62478
  • Feb 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
General karthief
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
T
Service Fluid Recommendations for 2015 Paxton Supercharged GT
  • ThotTrap
  • Aug 25, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 25, 2025
ThotTrap
T
