  • SN95 4.6L Mustang Tech
Differential leak...
  • Thread starter Thread starter GDawg
  • Start date Start date Aug 7, 2005
1 of 2 Next Last
GDawg
1,469
Nevada
Aug 7, 2005
  • Aug 7, 2005
Tomorrow I'm taking my car in for a leak coming from my differential. The guy said it could be a pinion seal.
Is that a major deal? If it is a pinion seal and not just a gasket (that I assumed it would be) would replacing the pinion seal cost any real bucks? I don't want this guy taking me for a ride. I've left the car parked until I can get that taken care of.
Any opinions would be greatly appreciated.
forpit2000gt
2,490
Columbia, SC
Aug 8, 2005
  • Aug 8, 2005
shouldn't be more than $ 100.00. is it leaking from the back or the driveshaft side?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Aug 8, 2005
  • Aug 8, 2005
I had found out my car had a leak when I got it and it was the pinion seal. I went to the best Ford dealership around here and it was still only $100. Its not costly if you catch it early before it destroys your whole rear-end.
04gtdrop
532
Sac, CA
Aug 8, 2005
  • Aug 8, 2005
i have the same issue, mine is leaking from the rear side of the Differential. can i fix this myself? is this a common prob? mine only has 22k on it.
under warrenty maybe?
hotrodnut
672
North Florida
Aug 8, 2005
  • Aug 8, 2005
I don't know what a dealer would charge to do it but my Son and I just did a pinion seal change on his '04 GT. The seal was only 5-6 bucks. His rear gear was set up without a crush sleeve using a spacer instead, with that it's just a matter of removing the Pinion Nut, changing the seal and torquing the Pinion Nut to spec.
If you have a stock type rear end set up you should change the crush sleeve when the Pinion Nut is removed. That is not that difficult to do just time consuming. All the shimming for the differential is just reused so no re-shimming is involved, you just have to remove the ring and pinion gear to get to the crush sleeve.
forpit2000gt
2,490
Columbia, SC
Aug 8, 2005
  • Aug 8, 2005
That is a lillte more involved than changing the seal.
04gtdrop: if the cover is leaking you can fix that yourself, very easy, need sealant, new fluid and a bottle of friction modifier. Just take the cover loose , leave the top bolt in but very loose pop the bottom loose to drain the fluid, clean all surfaces well, put sealant on cover, reinstall and fill with fluids.
LI98GTStang
1,715
L.I., NY
Aug 8, 2005
  • Aug 8, 2005
My pinion seal was leaking and had it changed also. Since it's going to cost 100.00 anyway, why not have the gears changed out while their in there?
forpit2000gt
2,490
Columbia, SC
Aug 8, 2005
  • Aug 8, 2005
No crush sleeve in 04s? when did that start. I've only been 8.8s up to 02.They all have them.
hotrodnut
672
North Florida
Aug 8, 2005
  • Aug 8, 2005
Why is that? If you remove the Pinion Nut (which is required to get the old seal out), it is required to replace the crush sleeve or you do not get the proper pinion bearing pre-load. If anyone tells you they did different, they are lucky to not have had problems.
hotrodnut
672
North Florida
Aug 8, 2005
#10
  • Aug 8, 2005
  • #10
The stock rear end set-up does have a crush sleeve, when putting the 4.56's and 31 spline goodies in my Son's '04 I elected to use a spacer rather than a crush sleeve.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 8, 2005
#11
  • Aug 8, 2005
  • #11
Sounds like yours is leaking from the cover. That's an easy fix. Do what forpit2000gt says.
forpit2000gt
2,490
Columbia, SC
Aug 8, 2005
#12
  • Aug 8, 2005
  • #12
you are correct, I read one thing and was thinking another. Was thinking about replacing the bearing as well and that requires the pinion to be pulled. Sorry about the misquote. You are correct about the crush sleeve. We always replace when changing a seal. I have always had a car on a lift and a long pull bar to crush the sleeve. I can't imagine working off of jacks or stands to crush that thing.
where did you get a spacer? haven't ssen one.
hotrodnut
672
North Florida
Aug 8, 2005
#13
  • Aug 8, 2005
  • #13
Yea, I have done some off jack stands and it's tough for sure. I also have a long bar to hold the pinion and have slipped a piece of steel pipe over the breaker bar to crush the sleeves, lol. When it's up on stands you don't get much rotation with each pull!
I got the spacer from DTS up in Michigan. http://www.drivetrainspecialists.com/categories/small-parts/products/product-1171.html
GDawg
1,469
Nevada
Aug 8, 2005
#14
  • Aug 8, 2005
  • #14
I couldn't find much fluid on my garage floor but it was all over the rear cover of the pumpkin. So I'm probably just looking at ~$100. That's not too bad. I would do the gears right now but I'm unemployed so I have to hold off on all tempation to sink any unnecessary money into my car right now. I'm living off my savings currently and it's painful to see money going out and none coming in.
Thanks for the input guys!
04gtdrop
532
Sac, CA
Aug 8, 2005
#15
  • Aug 8, 2005
  • #15
forpit2000gt: thanks for the heads up. Yeah my gears were JUST shipped out today. UPS says they will be here friday. I was going to wait and get the 31 spline axles and a torsen but i wouldnt have those until like november. So now that i have this leak i was thinking just pay to have the gears put in and do the axle and torsen later OR fix the seal now myself and hold off on the gears till i get my other parts. The shop that was going to do my gears said a flate rate of 400 bucks. I found another shop that sid just labor on gears would be 250. How does that sound to you guys?
I think i have lost a decent amount of fluid so i dont want to run the risk of blowing up my rear end if i wait. Just curious but, about how much fluid is in the diff? sorry for high jacking the thread....
GDawg
1,469
Nevada
Aug 8, 2005
#16
  • Aug 8, 2005
  • #16
That's alright about the highjack, at least it has substance and isn't just babble like another site I used to frequent.
04gtdrop
532
Sac, CA
Aug 10, 2005
#17
  • Aug 10, 2005
  • #17
ok, so i think i am going to try and fix this leak over the weekend. I am leaving for a short (110 mile) trip on sunday. So do you think it would be ok to fix this on sat? then drive a lonf distance like that? so in a nut shell all i need to do is drain it, clean the outside edge seal it and fill it up? any advise? has anyone done this before?
Hammer1999Gt
169
Toledo, OH
Aug 10, 2005
#18
  • Aug 10, 2005
  • #18
Mine is leaking from the pinion seal also I think. This seems to be a common problem
forpit2000gt
2,490
Columbia, SC
Aug 11, 2005
#19
  • Aug 11, 2005
  • #19
those with leaking pinion seals, did you have gearswap, did you do it yourself?
9
98laseredgt
122
indianapolis
Aug 11, 2005
#20
  • Aug 11, 2005
  • #20
i have a question here, the tag on the diff calls for 75-140 synthetic, so i bought valvoline synpower. on the bottle it says limites slip after the weight. and on the back it says its made especially for limited slip differentials. so i bought friction modifier from ford and used it too just to be safe. but do you have to use friction modifier with synth. fluid? i just re-sealed my cover because it was leaking, just to make sure i got enough permatex on there i put a bead on the inner and outer part of the cover and around all the bolt holes cause thats were it looked like they put it from the factory. is that right, im waiting til tomorrow to drive the car because the permatex says it takes 24 hours to completely cure.
1 of 2 Next Last
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Sunroof Woes
  • TIGGER
  • Feb 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2025
Snakbytn1990
