  • SN95 4.6L Mustang Tech
Difficulty on 4.10 Installation
  • Thread starter Thread starter 01mgvert
  • Start date Start date Mar 15, 2004
01mgvert
302
  • Mar 15, 2004
My Mustang GT has been at a local transmission shop for 2 days having 4.10 gears installed, along with the installation kit. On the first day, they removed the old gears and broke a part (s-spring?). On second day, they spent five hours putting in the new gears and still have not completed the work. They are suppose to be done some time tomorrow. I don't want to rush them because they are trying to do a good job. But, what the heck is taking them so long? Should I be worried?
03-s281
421
Stangville,TN
Mar 16, 2004
  • Mar 16, 2004
Hell yeah I'd be worried. Especially if there charging you by the hour.
My friend that works at a shop said about 4 hours.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 16, 2004
  • Mar 16, 2004
I took mine in in the morning and it was finished that afternoon. Now if they broke the s spring and had to order it I can see how it would take a little longer but I would think that it would be readily available. Also I'm not sure about the choice of shops. I would have gone with a perfomance shop who has experience with gears. Did they give you a quote? If they did hold them to it.
trublustallion
386
El Paso, Texas
Mar 16, 2004
  • Mar 16, 2004
damn, how much are they charging you by now?
01mgvert
302
  • Mar 16, 2004
I picked it up today
They finally finished with the 4.10 gears on my 01 GT. I was charged by the job, not by the hour. To replace the ring and pinion, I was charged $275 for labor. To replace the axle bearings and seals, I was charged an additional $338 for labor. I was not charged for any parts because I supplied the 4.10 gears and the installation kit. Do these charges seem reasonable?
G
ggarriso
137
  • Mar 16, 2004
Umm so waht your saying is you were charged
613 dollars? I dunno that seems very very steep for what
they accomplised to me.. anyone else?
billyfe390
573
  • Mar 16, 2004
I dont really know because I do it myself but 338 in labor for the axle bearings and seals seems a little high. First of all axle bearings in the 8.8 rarely need changing second it only should have taken maybe 2 hours to do unless they didnt have the slide hammer to take out the axle bearings.
normster6969
558
Huntington Beach, CA
Mar 21, 2004
  • Mar 21, 2004
You have to remove your axles when you change out your gears since you have to remove your differential. They just pop off the gears and seals and replace them for the axles while they have your axles off the car. Shouldn't have been $338 unless you didn't plan on taking the diff. apart and didn't realize they'd have to take it apart to get the axles off. The incremental should have next to nothing...
Hope they put everything back together correctly considering they were braking parts to get it apart.
Good luck,
Norm
03gtmustang
923
Northern Va
Mar 21, 2004
  • Mar 21, 2004
I was charged $200 for labor. All together I paid around $380, not including my chip.
normster6969
558
Mar 22, 2004
#10
  • Mar 22, 2004
  • #10
Will have accurate prices in a couple of days
My rear-end sprung a leak via the pinion gear seal. I had a Torsen Diff, 4.10 gears, and a TA cover sitting in my garage (how convenient) that will be replacing the lame stock crap. Also, I'll be adding some 31-spline superior axles. I'll post the labor portion of the price once I pick my car up. It's probably going to be around $300 for the labor based on my discussion with the shop owner (J&S Gear Company in Huntington Beach, CA).
I'll keep you guys posted...
Norm
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Mar 22, 2004
#11
  • Mar 22, 2004
  • #11
Dude are you serious? I got my 4.10 installed 2 weeks ago. I stood there and watch the whole thing...
cool down - 1 hour
installation time - 1 hour and about 10 min exactly..
result? no whine no noise... gunned it on the highway home no problem..
C
ChrisXoxide2
Banned
Feb 27, 2004
45
#12
  • Mar 22, 2004
  • #12
I installed my own ring and pinion, 7 hours or so?
I'd like to see a video of someone doing the job in an hour. They can't possibly be making all the measurements.
A
Aaron385
#13
  • Mar 22, 2004
  • #13
An hour?? Thats just wreckless!! I did it myself (alone) and it took me about 6 hrs or so (going at a slow pace).. Wouldnt reccomend a tranny shop to do a gear swap!! Thats not what they do.. go to a speed shop that does gears all day long.. I use to see this all the time.. you probably asked them if they "could" do a gearswap and they said yes.. when in reality they have had little or no experience with it. Thats why they took 3 days and broke parts! I think Im going to go ask the 10 min oil change place if they "could" rebuild my engine.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
