Dimmer switch
  • Thread starter Thread starter stang0f87
  • Start date Start date Mar 15, 2008
stang0f87
102
Fort Smith, AR
Mar 15, 2008
  • Mar 15, 2008
Gotta 87 gt. Dimmer switch just went out and costs $90.00 for another. Low on mula at the moment. Does anyone know how to bypass the switch and wire it straight. I hate not having dash lights. Thanx
D
diponyou
  • Mar 15, 2008
ebay.com 10$ i just had to buy one myself
stang0f87
102
Fort Smith, AR
Mar 15, 2008
  • Mar 15, 2008
actually i meant for a new ford one. i've tried used ones. this is my third. maybe there's some cheap knockoffs out there but i'd just assume bypass it and be done with it. anyone know how to do that?
HISSIN50
34
129
Mar 15, 2008
  • Mar 15, 2008
You could connect the dimmed circuit to the parking light circuit. Your instrument lights would be at full potential at all times.
Then you'd have to rig up a switch for the dome light if that function on the dimmer switch is also wonky.
stang0f87
102
Fort Smith, AR
Mar 17, 2008
  • Mar 17, 2008
actually thats the only thing that does work on the dimmer switch. the dome light control. for right now anyways. probly be a safer bet to assume the dome light function will ultimately fail too. any idea what wire goes where to bypass it completely?
Nova
128
  • Mar 17, 2008
junk yard. oem ford baby.
i just sold two to a buddy or ide send one your way.
Saleen0679
876
24
49
Yakima, WA
Mar 17, 2008
  • Mar 17, 2008
If you've been using the old style dimmer with the aluminum housing and coil rheostat you should try the newer style with the plastic housing and metal contact pads. Maybe it will work out better for you.
For a temp fix you can just run a jumper from the BR wire to the LB/R and bypass the dimmer portion of the switch while leaving the dome light switch intact. To bypass the dome light switch you would have to install a suitable switch between the LG/Y and BK/LB wires.
stang0f87
102
Fort Smith, AR
Mar 17, 2008
  • Mar 17, 2008
thanx saleen0679. i'll give that a try.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
