Direction I Should Go With My Build?
ry94stang50
427
12
Brick, NJ
Ok I was thinking about going the trick flow setup. I was going to buy the whole kit. Now I'm kind of thinking about going with gt40 heads and a better intake setup. Then down the road adding a supercharger or turbo. So what would be the pros and cons of each setup is one going to bring more power then the other?
One thought I've always had was with the GT40p iron heads or any bad ass iron head, is if they're ported REAL well and you put a power adder on it. If you ever had a boom go wrong, the iron heads could take more of a beating and you could live to fight another day. Believe aluminum melts around 1100 degrees and iron at 2100 degrees.
Realistically it all boils down to $. The gt40 plus forced induction will probably cost more in the end once you get all the supporting hardware. Here's another gt40 scenario to think about: say you save up I dunno like $1000 for the gt heads and intake of your choice u get em on and while you're trying to save another 3-4k clams for the poweradder you'll more than likely run into one or several other mechanical snags that come along w driving a 20 yr old car so there you are w financial set backs and gt40 heads and the saving cycle continues. On the other hand I guess the same could be said while waiting and saving up for the tfs topend. I think for reliability n longevity I'd go w the topend kit though. It's rough out there for a poor ole dreamer like myself
most if not all of the iron heads have a relatively thin deck to them, which is fine in an engine built for longevity not max power. Most of the aftermarket aluminum heads have around 3/4" deck height, which equates to more meat for your head bolts or even better head studs to clamp down on, meaning less prone to lift when boosted
I doubt this guy is concerned w splitting the block or lifting heads. Sounds like he's saving to do a build that will get him around the magic 300 rear horse mark. I'd venture to say that most folks saving for an engine build aren't going to save long enough to make 600. The saver and scroungers bank account will split long before his block
Reactions: 84Ttop
When we melt aluminum heads, they just go to the machine shop to get welded, no big deal. I melted a hole out the side of one not to long ago and for a few hundred dollars it was welded and remachined good as new. Same applies to aluminum blocks, they can be welded and repaired where cast iron can't. Just my 2 cents
People with non-DD's and money. Course putting boost on a stock block is a DD's time bomb anyways.
I say add the power adder with a better intake and enjoy the car....then save for a DART based long block setup.
Sent from my XT907 using Tapatalk 2
It'd cost em more to go that route than it would to buy a topend kit. He'd have to purchase gt40 heads lets say a conservative 500 dolla, then some intake-600, then supercharger kit 3k +
If he's spending that kind of $ he'd prob be better off paying $3,800 for the ford racing crate motor. Yes he wouldn't make the 300 hp at the wheel as he would or might w a topend kit but he'd have a new bottom end as well. Better yet here's an idea: buy the "economy" short block from latemodel and then purchase the tfs topend. Any of the options listed in this entire thread would put him in the $4k range but at least w the Eco shortblock and topend he'd have all new parts. If I could "like" my own post I would, this is the best idea I've had yet
