I think most of you guys checked out my past post about my 289 blowing up. The blocks might have a crack in it, and the piston is fused to the head.
Anyways, heres what my idea for the resureciton is, seeing that i dont have a ton of money right now to fix it. Find a used 289 block, or a new cast block, stuff it with my old cam, get new strong rods and pistons, stock crank, try and get the piston off the head if its possible, and use the same heads i have now, along with all the intake and exaust and ignition stuff i have now.
How much would it cost to find a 289 block, stuff it with my old crank, but with new rods and pistons, and the same cam i had?
Could i find a 302 block and use that with the parts from my 289? Ive heard that the 302 block is exactly the same except the stroke was longer. So, could i use a 302 block with 289 parts?
Last option, try and find a short block, and top it off with the parts i have. Are there any good 302 shortblocks or 289 shortblocks? For less then 1600?
Thansk guys, i want this car to be alive again.
Mike
Mike
