I started my car up today to journey over to the exhaust shop and disaster struck before it even left the driveway. First my battery was dead which is not a surprise since I've been having some charging issues with the car. Second once I jumped it, it ran great at idle... a little spuddering but not horrible at all. Third I put it in gear and it started to instantly try and die out. It spuddered hard and constantly needed me to put some pedal in. Car would eventually die out 1/2 way out of my driveway. I restart it and it turns over fine and runs just fine at idle. I pop it in gear it makes it to the street this time and then it dies. Now my battery is dead from restarting so often. I get out to jump the car and I see rainbow puddles down my driveway and on the street. Not good. So heres what I found...
Tranny fluid is leaking bad. It appears to be coming out right around where it mates to the motor. Maybe even around the front of the pan? I can't see too well with it running nor do I feel safe watching my tranny fluid pour out. This is no slow leak, its flowing pretty good. Enough to saturate a piece of cardboard after running for maybe 30 seconds. It does not leak when the car is off.
What happened?
Anyone know what would cause these symptoms? Car stalling in gear and tranny leaking from near where it mounts to the motor? I do hope its not the converter
--BTW this is an aod.
What happened?
