  • 1994 - 1995 Specific Tech
Distibutor install
  • Thread starter Thread starter 94TURBO5 O
  • Start date Start date May 20, 2004
94TURBO5 O
2,509
VA
May 20, 2004
  • May 20, 2004
When I installed my distibutor I turned the shaft a little. Is it possible that the timing gear or chain was moving down there? I searched and no one asked this question yet. I'm just curious b/c I could feel some resistance when I was twisting it. I will remember this exp. forever and learn right away to mark the housing next time!
stangbanger94
203
Bergen County, NJ
May 20, 2004
  • May 20, 2004
The timing gear and chain would not move unless you spun the motor. Other than that, your timing marks should be right on.If you're unsure, spin the motor by hand, and reset your motor to 0 degrees, and re-install your distributor, with the rotor pointing towards cyl #1
stangbanger94
203
Bergen County, NJ
May 20, 2004
  • May 20, 2004
This is as long as your cam wasn't degreed in anyway, and also remember that you may have to set your distributor a few times before it's right on the money
94TURBO5 O
2,509
VA
May 20, 2004
  • May 20, 2004
Good 2 Go! I am straight then...I didn't move the crank and it is still on zero. Nice! I can't wait to have this thing back together its been a month now.
Thanks!
zenboy99
2,212
Madison, WI
May 20, 2004
  • May 20, 2004
I would go ahead and check your timing anyway. I put in a new distributor last week. I marked the old distributor in 3 places, but when I put the new distributor in the same way, my timing was off 10 degrees. I have no clue how that happened, but I spent awhile wondering why my car didn't have any power and wouldn't idle
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 20, 2004
  • May 20, 2004
Sorry I guess its early for me...but what does degreeing the cam have an effect on the timing...do you mean since the engine has been rotated?...
stangbanger94
203
Bergen County, NJ
May 20, 2004
  • May 20, 2004
some cams can actually be degreed + or - certain degrees(advanced or retarded) on initial installation because they are designed that way. For example.. I had a wolverine blue racer cam(now discontiued), and for it to make the proper power it was supposed to, it had to be retarded (degreed) when I installed it. So that was what I was mentioning. You can't install that cam strait up and down like you can with a ford motorsport cam, or other cams. So that was why I was mentioning it.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 20, 2004
  • May 20, 2004
Alright...cool...so with my FTI cam I can degree it with the kit...and it isn't going to effect my installation of the distributor...I can just rotate the engine to 0 (TDC) and point the rotor to the #1 cylinder terminal under the cap...and put it in...
The whole degreeing the cam has got me confused...lol...I guess I'm going to "splurge" and by the video along with the kit...
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
