Distributer play in Timing?
  • Thread starter Thread starter 90mustangGT
  • Start date Start date Sep 26, 2004
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 26, 2004
  • Sep 26, 2004
I have noticed when setting timing with the plug pulled the timing still jumps around a degree or two. Is this a sign of a bad distributer? The Module went out last night (or so I think) and I was thinking maby I should replace the whole thing with a MSD or Accel unit.
04sleeper
2,674
14
89
Dallas, TX
Sep 26, 2004
  • Sep 26, 2004
Since you stated that your TFI went out last night or you think so it sounds logical. Also it might be slack in your timing chain.
90mustangGT
2,773
17
89
Dallas, GA
Sep 26, 2004
  • Sep 26, 2004
I put a new timing chain on when I did the cam which was less than a year ago. When I pull the cap and rotor, I can move the shaft enough that you can hear and feel the play, it is mush more noticable with the rotor attached. My buddy got a Billet MSD unit, it was real solid.
87'GTstang
1,025
  • Sep 26, 2004
You might want to check your distributor gear. It's not a very problamatic area but your typical distributor unit is a solid, one peice shaft and the only place where it could develope "slop" would be where the unit picks up the timing at - the timing gear on the bottom of the unit.
90mustangGT
2,773
17
89
Dallas, GA
Sep 26, 2004
  • Sep 26, 2004
Thanks, I didn't think about that but that makes perfect sence. I have scene the distributer drive gear advertised, I think I will pick one up.
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
