Distributor Age ?'s
Just when are you supposed to swap out the OEM distributor for a new piece? What are the tell tail signs of a worn piece? About how many miles will they perform well ? I've got 140K on mine and I'm wondering how much longer it'll hang in there. Or should I just check for shaft play and replace the cap and rotor? Any help would be appreciated.
It is hit or miss. That is getting up there though. The main wear items on a fox dizzy are the TFI, PIP and the shaft's bushings itself (which can affect things like the PIP).
If you feel like it, toss a new dizzy in. Otherwise, you could rebuild yours as you see fit.
Good luck.
At 140K if its the original and you have the extra cash, Id go for replacement. Better to replace it while its still got some life in it then to get stranded is the way I look at it. The ignition module (TFI) has a habit of lettin you down when you least expect it. (i.e. very late, far from home on a cold winters night)
