Distributor for a roller block
Falcon79
214
Dallas, TX
Hi guys,
I need an opinion or two from people that have actually been there. I have a carburated 1991 roller block 302 that I'm trying to get running. I can't decide which way to go with the ignition system. I like the pertronix distributors because they are simple and there's no ignition box to buy. Problem is they don't seem to come with steel gears which is no good with my roller cam. Does anyone have an opinion on which way I could go?
Hi guys,
If you want to use one, stick a steel gear on it and use it.
If you can't find a distributor like the Pertronix with a steel gear, next best thing is to use a Duraspark from an 85 Mustang GT with a manual transmission. The parts houses stock these in a reman unit for about $50-60 with a core to exchange. (Doesn't have to be the same exact core either, a points distributor will do) There are wiring diagrams floating about the net, there's basically 3 or 4 wires to hook up. Or do a gear swap, I've done two points distributors using a Ford Racing steel gear, it's not hard to do it, but you DO have to pay close attention when doing it, instructions are included with the gears. Only part in the structions missing is to be sure and not move the retainer collar under the housing (above the gear) You'll need a dial caliper to do it too, or some other tool to precisely measure the distance from the gear to the distributor body. Once the steel gear is in place and pinned, lube the gear liberally with moly grease to break the gear in with the camshaft gear.
I have an '85 GT 5-speed Duraspark distributor in my '68 with an HEI module to control the coil and I think both cost less than $80 combined with my old points distributor as a core. It's cheap and simple, but the HEI module is ugly and needs to be mounted to a heat sink of some sort.
im doing the same thing with the exact same year motor. I was gonna buy a mallory unilite. I remember you have to make sure you buy the right gear. Do you get a steel gear for a roller motor or something else.
Make it easy on yourself
Buy the MSD distributer, control and coil.
Detailed instructions, will work great and will never, ever let you down.
Just make sure what ever you do, on a roller engine use a bronze gear.
The steel one is no good!
Not trying to hijack the thread...but, which gear for the dizzy? I have a Mallory Unilte and need a gear for ..too many opinions and I haven't really seen anything said yet that confirms which way to go....
I'm using a '90 roller block/cam as well...
What I have in my 91 roller right now is the duraspark setup but I only have the dizzy and not the module, I would replace it with a new duraspark setup if i knew where to get it. Anyone know where i can find one?
Any parts house has what you're looking for. Take your pick. 85 Mustang GT with manual transmission is what you're looking for. That was THE only application for a Duraspark distributor with a steel cam gear.
I have a rebuilt '66 distributor in my '88 roller motor.
I use a steel gear (MSD#85833), and it required drilling a new hole for the gear pin.
The bronze gears wont last more than a few thousand miles, and i have NO idea why the mustang parts places sell them for the roller conversions.
