distributor shaft lenghts
wlabrum
26
went to order a dui style distributor of of ebay
was told there are 2 different shaft lenghts
as messured from bottom of gear to oil pump dive end
mines 1 1/2 inches long {donner car was 88 crown vic)
whats the deal and can i just change timing covers?
help thanks
i see that oil pump drive is diverent size also
im just tryin to build a carbureted bracket motor
original thick film distributor has no advance
and i see the block holds the other ends
crap i hate to have to buy another motor over bs distributor issue
aint got a lot of money so didgital is out
got sugestions?
thanks again:shrug:
not sure about measuring from the gear down..but maybe the clip depth measurements might help you a bit:
(note; this was based off retaining clip install hight issues...this may not give your enough info)
photodisplay.php
as meassured from end of shaft to bottom of gear (oil pump drive end) is 1 1/2" on 88 crown vic donner car
1 " on older distributor i had
dist shaft is also smaller diameter on vicky one
cant use thick film dist.
running carb and need mechanical advance (drag car vacuum not needed)
