  • 1994 - 1995 Specific Tech
Distributor wont go in?!#!@#
  • Thread starter Thread starter CivicEater
  • Start date Start date Mar 21, 2004
C
CivicEater
579
  • Mar 21, 2004
I had my distributor in and all was money...untill I popped it out to put the fuel rail line in place....I went to put the distributor back in and its a no go. I can hear a click as tho the oil pickup is sliding into the center as it should, but the distributor still sits about an inch above where it needs to be.....No amount of "twirling" the rotor or distributor will get it to slide down. What the F is goin on? Thanks
mytight95
2,605
Dothan,Al
Mar 21, 2004
  • Mar 21, 2004
sounds like the shaft for the oil pump is not sitting down in it the recess for the pump the way that it should. I would try shining a light etc and moving it to see if y ou could get it to slide back down in the hole, then try to get the dist in
jason
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
