Dizzy won't budge...?
Killer50stang
632
I've got my 351 tore completely apart. All that's left, is pull the freeze plugs, pull the dizzy and came. Timing chain and gears are off. The nut is off of the dizzy, but it will not turn. Take it, the motor has sat for 3 years. It seems you can turn the rotor but not the dizzy itself. Any tips in getting this thing out?
Yeah, piss poor design on Fords part to put an aluminum distributor into an iron block. The two metals dont like eachother at all. You can try soaking the hell out of it with something like BreakAway, PB Blaster or WD-40. Maybe also try a plumbers torch and lightly heat the iron block, NOT the distributor. You need the block to expand slightly NOT the aluminum distributor housing. Then try tapping lightly with a deadblow or rubber mallet to try and get it to start spinning in the block.
