Do 18" rims really slow you down?
I have been reading a lot of the forums, and there seems to be a few people saying that putting 18" rims on you car will slow it down because of the rotating weight you are adding. :shrug:
Does 18" rims really do this even if you keep the propper overall tire/wheel size?
Or is it that people put too big tires on bigger rims and mess up the speedo?
Thanks
~K
I'm sure it slows you down, but not significantly. I remember reading somewhere that it can have something like ~.1-2 off your 1/4. Probably just the weight. I noticed no difference when I went to my 18s though.
I remember using some online calculator before. 285/35/18's make you car read about 1% slower than it's really going. So if you're doing 101, it'll say 100. Not too big of a difference. Also, at least with my 2000 cobra r wheels, it seems like it would be the same weight if not lighter, since there's less tire. There is only about a cubic inch per spoke being added, so what's heavier? 5ci of wheel or 1" of tire all the way around? I don't know, but it's close.
answer is dependant on the wheel wieght and tire size. If you run a lighter than stock forged 18" wheel with the same diameter tire as stock then no.
if you run a 30lb 18 wheel with larger diamerter than stock tire then it can slow you down a bit.
A light 18" rim with the right tire size is going to be very neglegable on hindering the performance. you could even run forged 19" on 30 series tire if you wanted to buy $500 a piece wheels.
All things being equal though a smaller wheel will wiegh less. a forged 17" wheel will be the best choice for the quarter mile. there may even be some 16" wheels that will clear the factory brakes but I am not positive on that. now if you wanted to run some exotic brake setup with 4-6 piston calipures and 14" rotors 18" wheels may be the best choice for auto x.
As for you speedo just keep you same overall diameter and everthing will be the same.
it slows you down a bit. like stated above, its not the size....its the weight.
the expensive wheels i bought were actually lighter then stock bullitts despite the 18 in. size. it was the wider tires that added all the weight.
dont forget when people do rims, either 17's or 18's they go from 245 to 275 or maybe 295. that is what adds the weight and will slow you down.
like i said even with 17, when you throw on a huge tire your adding weight.
i weighed my wheels before and after the tires. stock bullits and the 18 in. bbs. trust me the weight is in the tire.
I'm sure they do. Just like someone already said, even if the 18's weight less, the wider tires will make up for it and i believe rotational inertia will actually multiply the affect. So if your new set-up weighs about 7/bs more per tire/wheel, the effect will be greater due to the rotational force.
I agree with the weight/sidewall thing.
Bigger wheel/wider tire = more weight..
Shorter sidewall = less sidewall flex..
Less sidewall flex means less traction/grip off the line.. that's why you see all those drag cars with 29" slicks/radials..
If i had a lower gear, i would've used some 15x10" wheels with some 29" DR's on them this past weekend, but it would've slowed me down due to the additional tire height..
