Do drag radials need to be balanced?
  • Thread starter Thread starter Quikstang
  • Start date Start date Feb 27, 2007
Quikstang
846
Orlando FL
Feb 27, 2007
  • Feb 27, 2007
Ok, i know this sounds like a pretty stupid question.. But seriously.. the first time I do a burnout, isnt that going to throw them out of wack?? I used to always get them balanced, but now thinking about it, I dont drive the but maybe 150 miles a month... I mean, its only a few extra bucks to do it, but if burn outs pretty much throw the balance out of whack.. why do it?? Or do burnouts have nothing to do with it....
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Feb 27, 2007
  • Feb 27, 2007
Well you are technically correct, but the effect isn't as dramatic.
When you do a burnout, you burn rubber off the entire surface of the tire. The amount of rubber should be evem so it should not really affect the balance of the tire.
Of course, it won't be even, so over time it will eventually work it's way out of balance, but it's not going to happen on the first burnout you do.
They will prob be work down before they are in need of being rebalanced
Quikstang
846
Orlando FL
Feb 27, 2007
  • Feb 27, 2007
lol, I figured as much. It was just running through my mind, Getting my new set put on tommorow for FFW spring break shootout. Just a though. Lol
Thanks!!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 27, 2007
  • Feb 27, 2007
One other thing to add is that if you run to little air preassure in them and your tires slip on the rims then that would throw them out. I know this can be an issue with slicks not sure bout drag radials as much.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
