88dragtop
If it were me I wouldn't run the motor any more until you could do a leak down or compression test to narrow the problem. Running it with the milkshake can toast your bearings quick. It could be HG, intake gasket, or maybe even the dreaded crack
Doing some of these diagnostic checks will help narrow it down otherwise it's just internet guess work. If you don't have access to compression testers try pulling the plugs and look for odd colored plugs, usually look all white from antifreeze.
Also,
don't use felpro 1250, it doesn't fit the 289 heads front water port well, atleast not mine. Not sure on the HG's but I'm pretty sure the old heads have a hole in the middle of each cylinder bore that the newer motors don't.
Also,
I guess you've never run across Trans-Dapt's and other's 2 bbl to 4 bbl carb adapters.
More than likely, the car needed a new carb and when they was the price for the O.E. 2 bbl, this was a cheaper solution.
