  • SN95 4.6L Mustang Tech
Do I have a gear?
  • Thread starter Thread starter Question
  • Start date Start date Dec 15, 2005
1 of 2 Next Last
Q
Question
21
  • Dec 15, 2005
How can I tell if my car has a 3:73 in it or not? My first gear can only get to 35. It's right at the red line at that point. Do you guys think I still have the stock gear, or does this mean I have a 3:73, or a 3:55? I'm basically just trying to figure out how long my first gear should be, assuming it's a stock gear. Thanks for the help.
triggz
1,218
Gadsden, AL
Dec 15, 2005
  • Dec 15, 2005
What year/model is your car? If it a mach1 it will have 3.55s. 99-04s have 3.27s stock, and 94-98s can have 2.73s or 3.08s.
Theres no way to tell you exactly what gear you have without knowing your year model, tire size and transmission type, and exactly what MPH vs RPM you see.
The definitive way to tell is to jack the rear of the car up, put a paint mark on the driveshaft and start rotating the tires. For every 1 rotation of the tires, the drive shaft will make X number of rotations, X being your gearing.
IE, if your car has 3.27s, 1 rotation of the wheels equals 3.27 rotations of the driveshaft. You can also do more than one rotation of the wheels and then divide the number you get by X number of wheel rotations for better clarity.. 3 wheel rotations = 9.8 of the driveshaft with 3.27s, but will be 11.25 with 3.73s.
trinity_gt
3,125
81
99
Canada
Dec 15, 2005
  • Dec 15, 2005
According to my quick calcs, with a 3.38 1st gear (Tremec 3650) and a 3.73 rear, together with "standard" 245/45R17 tires, you'd see about 5950RPM at 35MPH in 1st gear. With 3.27s you'd see just 5216RPM. 3.55s would give 5660 and 4.10s would give 6539RPM.
I'd venture you've got 3.73s in there assuming your tach & speedo are both reasonably accurate.
BlackenedSVT
1,841
New Jersey
Dec 15, 2005
  • Dec 15, 2005
Just for refference, the 94-98 cars had 3 options in gears. my 98GT came with 3 gear options in that year and they were 2.73, 3.08 or 3.27. All automatic GTs from 94-98 had 3.27 rear end gears i believe. I know when i swapped to 4.10s in my (automatic) 98GT, the mechanic pulled out 3.27s =)
Outlaw97GT
234
Redneckville, Tx
Dec 15, 2005
  • Dec 15, 2005
My 97 auto has 3.08's, 3.27 was an option for all 96-98 GT's
Just do what triggs said, jack the rear of the car have a friend spin your
tire "1" time and you count how many times you driveshaft goes around.
If it only goes around a hair over 3 times = 3.08's or what ever size gear you
have.
Or pull the cover and count the teeth and divide together. Dont trust the tag
if you got the car used, might have been changed.
Q
Question
21
  • Dec 15, 2005
It's a 99 GT. It moves pretty good for just exhaust. It's very loud and seems to pull pretty good down low, which is why I was curious. There is no way to tell if the guy who had it put a 3:73 in it. Which seems pretty logical, since he has this really loud exhaust without any cats or anything...At 35MPH the car is right at red line. Almost 6. Does anyone else have a 99-04 GT with a stock gear, that is different from mine in first gear?
By the way, the car does have standard tires. (245/45/17) Stock rims and tires.
Venom_Nitrous
416
Spearfish, SD
Dec 15, 2005
  • Dec 15, 2005
3.27's
1LowGT
294
st louis mo.
Dec 15, 2005
  • Dec 15, 2005
my 98 gt auto had 3.08s
CanadaStang
2,093
Mb
Dec 15, 2005
  • Dec 15, 2005
OMG!!! Mr. Lt1 bought a......a...... Mustang???
[Twitch]
168
Montreal
Dec 15, 2005
#10
  • Dec 15, 2005
  • #10
3.27 T45 in First gear at 6000rpm > 41.598073050691 MPH
3.73 T45 in First gear at 6000rpm > 36.468015784386 MPH
Tire size is 245/45/17
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Dec 16, 2005
#11
  • Dec 16, 2005
  • #11
1996-1998GT
2.73=maunal
3.08=auto
3.27=optional for either
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Dec 16, 2005
#12
  • Dec 16, 2005
  • #12
What's your rpm in 5th at 55 mpg?
Q
Question
21
#13
  • Dec 16, 2005
  • #13
So, this would assume I have a 3:73. Where did you get this information by the way? Is there a link? There is no way my car can go 41 MPH in first gear...
Q
Question
21
#14
  • Dec 16, 2005
  • #14
I'm going to go and find that out right now. You mean 55mph, right? All of a sudden were talking about gas, lol.
CanadaStang
2,093
Mb
Dec 16, 2005
#15
  • Dec 16, 2005
  • #15
This should help:
http://www.wcfords.com/stuff/calcs/EGTcalc/egtcalc.php
Q
Question
21
#16
  • Dec 16, 2005
  • #16
Alright, at 55 mph my car is over 1500 rpms. I would say, 1600 rpms or so...
Q
Question
21
#17
  • Dec 16, 2005
  • #17
CanadaStang said:
This should help:
Maybe I'm dumb, but I can't figure out that thing...
trailblazr81
571
Hollister, Cali
Dec 16, 2005
#18
  • Dec 16, 2005
  • #18
Its simple, fill out the stuff you know, pick yer gear n tranny then it calculates whatever field you left open.
The 55 MPH at 1600 RPM would be the 3.27's if its a T45 or TR3650.
Go buy some 4.10's.
Outlaw97GT
234
Redneckville, Tx
Dec 16, 2005
#19
  • Dec 16, 2005
  • #19
You have a 99 GT Im assuming its a 5sd since you didnt say, and Im also assuming you have 245/45/17 tires. If so and if you were at 55 mph in 5th gear(Im assuming again) at 1600 rpm here is your gear size=Result:
Rear End Ratio = 3.3172798206155
That means you have 3.27's...
imblown-ru
247
Roanoke VA
Dec 16, 2005
#20
  • Dec 16, 2005
  • #20
hmm so my mustang can theoretically do 209 mph? thats what that webpage says...im gonna go try
1 of 2 Next Last
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
