Do I need a tune after switching intake manifolds?
  • Thread starter Thread starter ScortLX
  • Start date Start date Nov 25, 2006
ScortLX
261
Parker, Colorado
Nov 25, 2006
  • Nov 25, 2006
Hello...I'm probably going to be putting the Trickflow intake and a 75MM TB on my car this spring and I've heard that that kind of large change can have a serious effect on the a/f ratio. Do I need to tune the car at the same time? Or will the stock computer make sure the a/f ratio doesn't get to a really bad level? I may tune the car late summer, but wasn't planning on tuning it right after I got the intake and TB on the car. What does everyone think?
steveb24
555
wilmington, DE
Nov 25, 2006
  • Nov 25, 2006
id get the a/f checked
3,287
24
69
Broke
Nov 25, 2006
  • Nov 25, 2006
Who knows - depends how effective that intake is... I'd lean toward the "it'll be fine with stock tune" side though... but with almost any mod a tune will get you more power from it though.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Nov 25, 2006
  • Nov 25, 2006
I would almost guarantee that you will.Wouldn't hurt to check your a/f.I will be going threw the similar thing as i just picked up a fully ported Bullitt intake last week .
ScortLX
261
Parker, Colorado
Nov 25, 2006
  • Nov 25, 2006
I'll probably run on the dyno to check where my a/f is at after I get the intake on. I just won't have enough money to buy a programmer or get a tune until later in the summer. Hopefully the a/f will be ok enough to drive for a while if its off. We'll see. 1Low...let us know how your a/f changes with thew new intake, congrats!
jstreet0204
939
Winston Salem, NC
Nov 25, 2006
  • Nov 25, 2006
Changing the intake should not throw off your a/f ratio. Neither should changing the TB. If you don't change the flow characteristics through the MAF it will addapt until it saturates.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Nov 26, 2006
  • Nov 26, 2006
Thanks ,i will .Maybe we can have a comparo of the 2 intakes once we are done with the install.LOL!!
I would think it would as the runner lengths will be different,port size will probably be different aswell,and this i would think would change the characteristics of the air flow,or the amount of air flow.Considering an engine sucks/pulls air like a vaccum.
I was told by two tuners that i'm reclose friends with that i would need a tune after the install of the Bullitt intake.Why would they tell me that,to make money off of me,cause they don't. When i ported my stock upper plenum,and my stock throttle body,it needed a retune,so a can't see changing out to the Trick Flow intake not needing a tune.
Not arguing .Just curious!
jstreet0204
939
Winston Salem, NC
Nov 26, 2006
  • Nov 26, 2006
Simply changing the amout of air that goes into the engine does not change the flow characteristics of the MAF. The things that change it are clocking the MAF, putting a bend infront of it, basically anything that changed HOW the air flows across the wire in the meter, not how much. Changing things after the MAF do not effect its reading. That is simply not how it works. Spend some time reading Ed Clarks articles on MAF based fuel injection.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Nov 26, 2006
  • Nov 26, 2006
the ECU can handle a Bullit intake swap without needing a retune, so the Trickflow shouldn't be any different.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Nov 26, 2006
#10
  • Nov 26, 2006
  • #10
pray that we get gains over 10rwhp
ScortLX
261
Parker, Colorado
Nov 26, 2006
#11
  • Nov 26, 2006
  • #11
I sure hope it puts out more than 10rwhp, I'm actually just looking for a good gain across the board. If it make 10rwhp peak but gains power throughout the power band I will be a happy camper! 1Low...sounds like a plan! LOL Keep us posted on your install!
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Nov 26, 2006
#12
  • Nov 26, 2006
  • #12
jstreet0204,makes sence what you are saying,i guess i will see next spring once it is in.
I will,but my install will not take place until spring .Stang is away now for it's sleep.But rest asure i will keep an up date.
If you get started before i do seeing that the Trick Flow should be out in Jan '07,make sure you keep us up dated!
ScortLX
261
Parker, Colorado
Nov 26, 2006
#13
  • Nov 26, 2006
  • #13
No problem 1low! I may get the intake in February, but my car is my daily driver and I don't know when the weather will cooperate to do the switch here in Colorado. Well, no matter what, I'll post some before and after numbers and install impressions whenever the swap happens! Hopefully its sooner rather than later, but who knows!
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Nov 26, 2006
#14
  • Nov 26, 2006
  • #14
It's going to be interesting.Can't wait to see what the Trick Flow does for you!
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Tuning help! - HEGO 2 @ 64 volts!!!
  • VenomousISA
  • Feb 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Feb 26, 2025
VenomousISA
