do i need distributer?
  • Thread starter Thread starter 85/96gt
  • Start date Start date Jul 27, 2004
85/96gt
131
  • Jul 27, 2004
sorry i probobly spelled that wrong..
after rebuilding my engine should i get a new distributer? do i ned to? is there rebuild kit for it maybe? it does have 150 k on it can i rebuild it or what?
thanks
mustangsquared
828
new bern nc
Jul 28, 2004
  • Jul 28, 2004
I would. What does the gear look like? Is it worn? You can replace the gear and the module (SP?) on the side or just replace it. I would get a MSD. With a rebuilt engine why chance a weak or inconsistant timing spark. A worn distributor will cause the spark to wander..IE when setting the timing does the "mark" move around (bounce around) a few degrees? If so then that is a worn gear and needs to be replaced. Setting timing at 12* means it will fire at 10*-14* .
85/96gt
131
  • Jul 28, 2004
alright thanks.. im pretty strapped for cash .. definatly not buying a new msd.. what would be the best of my options here?finding a used one cheap? putting a new gear on it?
mustangsquared
828
new bern nc
Jul 28, 2004
  • Jul 28, 2004
I would get a new gear if you need it...the fast check for a gear is to open the dist up and shake the rotor...too much left to right movement is bad. 50 restoration has them. They also carry new moduals. (or you can get a screamin demon modual $55).
Paint and Body Cowl Pan
  • jeremyzcook82
  • Sep 13, 2026
Fox 5.0 Mustang Tech Oct 3, 2026
Rcdgl
R
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • brandyn200
  • Jun 20, 2026
AeroCoupe
