DO I NEED THESE???
  • Thread starter Thread starter 1980coupe
  • Start date Start date Oct 16, 2007
1980coupe
CHICAGO
Oct 16, 2007
  • Oct 16, 2007
JUST CONVERTED MY 80 COUPE TO A 5.0 5 SPEED! USE TO BE A STRAIGHT SIX AUTO! I USED A 84 GT AS THE DONOR BUT THE 80 DOES NOT HAVE THE QUAD SHOCK MOUNTS AND THE HOLES IN THE CONTROL ARMS FOR THE SWAY BAR! SHOULD I YANK THE GT CONTROL ARMS OUT AND QUAD SHOCK MOUNTS AND FAB THEM TO THE 80 COUPE? OR CAN CAN I DO WITH OUT THEM AS FAR AS DRAG RACING IS CONCERNED! OH AND YES I USED THE COMPLETE SUBFRAME AND SUSPENTION FROM THE GT AND WHAT A DIFFERENCE I TELL YOU!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 16, 2007
  • Oct 16, 2007
The quad shocks are a roll of the dice. No matter what the combination of tires, control arms and shocks, some cars will wheel hop without quad shocks and some won't. There are so many variables in 28-13 year old cars with wear, misalignment and combinations of suspension components and tires that one unchanging answer won't work for everyone.
I personally would install them, and make sure they are in good shape. I do know this, that Ford is cheap. If they could have made changes in some simple component like bushings or control arm construction and saved $10, they would have done it. Multiply $10 times all the Fox body Mustangs ever made and you would be almost as rich as Donald Trump. That's a lot of $$$, and good incentive to engineer something to do away with the quad shocks.
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 16, 2007
  • Oct 16, 2007
Replace your rear end bushings with high durometer stuff and get a good set of control arms and you can ditch the quad shocks. They serve the same purpose as the dogbone on the rearend housing(thread starters on mustang forums).
tbovee
129
Fredericksburg Va
Oct 17, 2007
  • Oct 17, 2007
I installed them on mine when i did the Gt conversion. Mine was a 2.8l. I swapped "everything" underneath from a 90gt.
P
PJB
131
Rotterdam, NY
Oct 17, 2007
  • Oct 17, 2007
Get aftermarket control arms and use the stock GT swaybar.
With aftermarket control arms you wont really need the quad shocks.
D
Daggar
3,902
  • Oct 18, 2007
Duplicate thread
--closed--
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
P
Hello, core supports for '86 vs '90-3, i need some answers if anyone knows
  • Pony Dr.Mike
  • Mar 14, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 15, 2026
95steedamustang
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
28"x9" tire clearance
  • Sparky714
  • Jun 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2025
Sparky714
