Its pretty easy without lift. I did it with 2 $9.99 Walmart special jack stands, 2 Rhyno ramps, and floor jack. And mine was hard due to BBK LT(I had to take them off first). If you have stock manihold, i think i can do my clutch now at around 5 hours tops.
Without dropping K-member, thne hardest thing is going to be the following
1-Starter. i haven't yet to be able to take starter out without taking K-memnber off. But i've told it might take hours to just get to the top starter bolt(mostly spent on looking for the bolt)
2-takeing top belhousing bolts off. u'll need something like 3.5' extensions to leach it, after you let rear of trans hang down.
Beawere of these top bolt. DO NOT USE 12PTS socket! if you don't have 6pts socket(i think it was 13mm), go buy one. otherwise, you'r going to be OWNED hardcore like Tomstang and I got owned
3-Aligne input shaft. if you have buddy helping ya, makes it much easier then otherwise doing it your self like i did.
