do these fit??
jimsstang91
101
i am changing my 4 lug to 5 and i bought 13' rotors and cobra calipers .so i'm about to buy the 94 mustang spindles and the ad said 11' spindles capable of excepting 13' rotors. my question is i thought the 13' bolt right on?now i need something else to make these fit.???:shrug:
You should have no problem with fitting the 13" rotors on 94 spindles. 94-04 Cobra front brakes will work on 94-98 spindles. You just need the caliper brackets to work with the increase hat height. As far as wheels go any 94-04 17" rim should clear the 13" rotor, the only problem comes with the spare tire, the GT spare won't clear a 13" rotor so you have to find a Cobra spare or swap tires front to back if you get a flat on the front.
these are the calipers i bought. M-2320-AF - 2003 Cobra 10th anniversary Calipers in red with pads and brackets. so these come with brackets correct? it fits 1994-2004 cobras and 1994-2004 gt's
old_blue said:
just need the extra bracket to fit on the caliper. plus what was mentioned above about the spare.
What is this Bracket you Guys speak of? My Cobra Calipers bolted directly to the Spindle, no bracket. I can say that it sounds as if he will need a set of front brake lines to fit the Calipers on.
It is the bracket that connects the caliper to the spindle. Some kits come with it some don't. When people sell the calipers from a cobra sometimes they don't include this bracket. I was told this when I was buying a set and backed out as I couldn't find it. This is what I have been told many times that a GT caliper bracket will not work as the caliper is larger. If this isn't true then I am going to get very pissed off and I will apologize for posting the wrong information.
regardless it sounds like you have everything you need.
Maybe I am wrong, but I swear my Cobra Calipers are 1 piece, there was no bracket involved and it bolted directly to the spindle.
